cb7 accord and other random shit
  • I wish I could trade my heart for an extra liver, just so I can drink more and care less.
    • The shop told me I didn't fit very well due to my awesome ebay header does not sit straight so a couple extra bends had to be made. Also at the back the exhaust sits really close to the sway bar and frame rail so the muffler had to sit off to the side just a bit. But overall I'm happy with it. It's hung nice and high and sounds really good. Super quiet inside the car. Haven't heard it outside but my friend says it sounds kinda like a fart can. Not good but I don't care, sounds good inside hahaha. They also put in an extra o2 bung so it's wideband ready when I get my aem.
          • sounds nastay! kudos
            lol gotta love that brake lamp light
            • Thanks. It's a little farty from the outside I guess but oh well.
              My wideband showed up today
              I think I'm going to mount it inside the glovebox.
              • Bought a cheapo oil psi gauge so I could use the mount
                Debating whether I want to loose the functionality of my glovebox or not. It really just holds insurance cards and trash. I could find another place for that stuff. If i do find another place, I'm going to make a plate for inside the glovebox that will hold my vafc, wideband, an oil pressure gauge and water temp gauge.
                • Went ahead and made a plate for the glovebox today. I spent pretty much all day on it and had it about perfect then I drilled the bottom two mounting holes in the wrong spot...... but at least I have a good template to cut another plate if I can't deal with the two extra holes
                  The plate after test fitting it at least 100 times. The cutout for the latch sucked big ones.
                  In the box
                  To mount it inside the box I used some angle iron, bolted that to the box and drilled hole in the front side with some of those clips that you can put a bolt in (I have no idea what they're called)
                  I used one piece on top and two smaller ones on the bottom
                  You can see the two nuts holding the angle iron in. The front two are under the leather cover over the front of the box
                  Used some allen head cap screws to bolt the plate in. You can see on the bottom where I misplaced two of the holes. I may be able to deal with it for now.
                  Still haven't figured out how I'm going to make holes for the gauges, but I'll figure it out when my other two gauges come. Hopefully by the end of the week.
                  • Killed my front lip on the parkway yesterday. Gotta find another legend coupe lip now.
                    • Really nice work! The flush mount spoiler is really unique. What did you use to paint the trans?
                      • Metallic silver krylon. Ended up not using that trans but it sure looks shiny sitting in my shed.
                        • What muffler is that? It looks pretty much exactly the style I want to go with on my Integra.
                          I/G: DeltaAlpha9
                          • Vibrant single inlet dual outlet. It sounds good if I keep it under 3k rpm. Above that it's kinda farty sounding but It'll do for now until I can find an apexi ws2 at a good price.
                            • Thanks. It's decently priced too. It shouldn't be to bad, my exhaust already has a resonator in it (until I wear a hole through it...) so it should take a lot of the rasp out of it.
                              I/G: DeltaAlpha9
                              • Crunch.
                                Totaled. A 200 year old oak tree fell on it yesterday. It also fell on my brothers new g6 and my toyota pickup. The g6 looks like it went through the crusher at the junkyard. The toyota came out ok but it might be totaled as well.
