Since you got a welder, go ahead and undo the floors you made before, and make a proper 1-piece metal floor welded. Alex will thank you for it on the next drive.
69 BMW Euro Trash
were not quite on that level yet with the welding, also metal isnt cheap and you cant weld street sign, they will be redone well sometime, but it probably wont be until summerOriginally posted by TeckniX View PostSince you got a welder, go ahead and undo the floors you made before, and make a proper 1-piece metal floor welded. Alex will thank you for it on the next drive.
So here's my part of the build.
We got the car to my house. It was probably the easiest car transport I've done. (Thomas's MKII fell off a ramp popped a tire ripped a hole in the floor and last time we trailered the 02 it get wedged on the trailer going on and we had to use a winch and like 5 people while it was raining.)
Anyway on to the build. First thing I did was clean the windsheild. It was gross as hell. Then I took some better photos with my car
Then we started work. As you've seen above we made a new exhaust. Basically we took the old side exit exhaust off of a truck (because we wanted the chrome tip and the glass pack) and chopped it up so it would fit on the 02 from the axle back.
Here's the car in the air, old exhaust off and new one being cut up.
Some bits and peices
A nice interior shot. I'm going to work on cleaning that up today.
Here's our test fit. Basically we have an inverted connector at the end so we can run the glass pack. It fits snugly and it works so we just have to get it hung properly.
I spent a little while examining and cleaning around the carb. It looks to me like only one side of it is getting fuel. Not sure why but it also might be two stage and I just wasn't opening it up enough.
I cleaned up the filter housings.
It's still a little rusty but it's a lot better than it was.
Nice front end shot. I actually really like the beige with the black front valence.
This is one of our many parts boxes. That's our spare radiator for when the JB weld on this one breaks.
As far as the engine goes. Right now it runs. But it has to have the choke about half way out. Which is making me think it;s having ignition problems. But I think it might just be this disgusting fuel filter.
Here is the finished exhaust. It needs to be raised up and shortened but otherwise it looks decent. As far as the tip goes it's going to be rotated and polished so it looks nice.
Here's a nice engine bay shot. You can see the carb running with no filter. We can't find a replacement anywhere and the old one is to dirty to use.
As far as what's left to do obviously brakes. We're also going to take the diff down to a metal shop and have it welded because Like Thomas said we're still not the best welders. Other goals are to get the floor pans re done. The gas tank needs to be bolted down properly. We're going to make a harness bar. I've got my old harnesses from my e36 that we can throw in it. And I need to diagnose this running problem. We found water in the oil and so i'm assuming the spark plugs are fouled. It might need a head gasket. But that shouldn't be to hard.Last edited by jrcanes55; 12-19-2012, 10:13 AM.
Here's today's update!
We had an extremely busy day. We got up reasonably early for some college kids (12) and got to work.
First up I threw on a new fuel filter. The old one as seen above was ruined. The car is running a little better now. But it still needs plugs and an oil change.
Then Thomas spent about an hour getting the calipers lined up and the lines hooked up. They were a bitch. I finally knocked the last pad retaining pin in. (say the 10 times fast) and we got them bled.
In between the install and the bleeding we went to a friend's house and got his 328isish runningish. It's in rough shape. All it needed was a battery and some gas and it was good to go.
And I also hooked my stock airbox up on the E28 to get every last ounce of power out of that motor. I raced the 328 and kept up very well. It has an M50 with silicone intake boot and an intake.
After we bled the brakes we took the car out for its first real drive. It did really well. It's having a little trouble in the high RPM but otherwise it's fine.
Here's my car and the 02 and my fixie.
Next on the list was to get that nasty not chrome exhaust tip chrome. I polished it a bit and I'll finish it up tomorrow.
Then I finished up my switch board that I made. I still need to find 2 more things to hook up
Thomas welded the fenders to the body so they stop flapping in the wind
Then I spent forever wiring it up. I had to change wires around and get them re organized and figure out what was what. I accidentally wired the horn into a constant positive and scared the shit out of myself and my dogs. Although on a good note I finally got the horn working.
Next to tackle was the not working tail lights and the braverse lights (The reverse lights come on when you hit the brakes. I changed some wires around and moved some bulbs and ta-da! Lights! Lots of them.
Backed the car out and it's so cold the exhaust literally looked like a steamboat. Sorry for the shitty pick. Best I could do.
Otherwise it was an extremely productive day. We got way more than we anticipated done. Tomorrow we're taking it to it's first ever car show in Burlington. It will have the E28 to keep it company.
Thomas took a few videos of both my new exhaust and the 02s so hopefully he'll post those somewhere. Both cars sound awesome.
Can I just humbly submit something to this thread...? You really need to work on the things that matter about this car right now, like fixing rust, making it legal, etc. Your exhaust, and many other things that you will feel like working on, are inconsequential at this point. Right now my daily driver is completely apart, and ive spent probably 40 hours in the past week on rust repair. It sucks, believe me, I know, but it has to be done before I can mess with my stance, and making the car how I really want it to be.
Im not ****** (that says h-a-t-i--n-g, i dont swear haha) on your car, because its yours and you should be allowed to make it your own, whatever that means. I realize that a lot of the things that are wrong with this car are because they were your first attempt at something, and you didnt know what you were doing. Thats fine, my last car was like that. I broke sooo much stuff on it haha, I made soooo many things far worse before they got any better.
Anyway, this post isnt about me. As I said, this is your car and im not going to **** (that says h-a-t-e) on it. All im saying (and I think most people will agree with me, or have already agreed with me, on this) is use common sense, actually fix things instead of doing something that is temporary. Make this car something you can be proud of. I understand its pretty far gone, that most people would have junked it anyway so it doesnt really matter (I have a 71 vw squareback that is close to the same condition, so I understand that as well), but please, make it something that your proud to show to other people. Do actual work on this car, research things before you attempt them. It doesnt cost a fortune to do things right either, I have basically no budget for my cars and I make it work. Its possible. Its not about making the car perfect, or doing it how other people tell you to do it or exactly how they did it, as long as your proud of it that is what matters. I guess all im saying is make the car something your proud of, do work that you are proud of. If your proud of what you have done so far or what this car is right now then I dont know what to say, and all of this may have just been for a lost cause. But thats really all I have to say, sorry if this was really long winded, but I have nothing else to do on vacation right now
If everything that I said was just baloney then im sorry, just take it as some weird guy raging on the internet. But I hope this does make sense, and that I know you I want your car to be awesome just like you do.
Keep going
EricLast edited by absentee; 12-20-2012, 04:07 PM.
Everything you said is true.You'll notice though that everything that has been done today (well almost) was in fact to get this pile of junk back on the road. I don't disagree with you. I would love to be able to tear this thing down and make it like new. But that just isn't going to happen. It's not a daily driver and if something breaks there really aren't any repercussions. We're using this car to try things and learn from mistakes we make. For instance I am learning how to weld. Today I did my first caliper install and completely rewired the car (for the fourth time.) Each time I've gotten better. And although cutting springs isn't the smartest thing to do, I learned on this car how to do it the best way. Which I then translated to my E28 which sits perfectly.
To be honest getting on the road today was quite an accomplishment and I'm very happy.
Originally posted by absentee View PostCan I just humbly submit something to this thread...? You really need to work on the things that matter about this car right now, like fixing rust, making it legal, etc. Your exhaust, and many other things that you will feel like working on, are inconsequential at this point. Right now my daily driver is completely apart, and ive spent probably 40 hours in the past week on rust repair. It sucks, believe me, I know, but it has to be done before I can mess with my stance, and making the car how I really want it to be.
Im not ****** on your car, because its yours and you should be allowed to make it your own, whatever that means. I realize that a lot of the things that are wrong with this car are because they were your first attempt at something, and you didnt know what you were doing. Thats fine, my last car was like that. I broke sooo much stuff on it haha, I made soooo many things far worse before they got any better.
Anyway, this post isnt about me. As I said, this is your car and im not going to **** on it. All im saying (and I think most people will agree with me, or have already agreed with me, on this) is use common sense, actually fix things instead of doing something that is temporary. Make this car something you can be proud of. I understand its pretty far gone, that most people would have junked it anyway so it doesnt really matter (I have a 71 vw squareback that is close to the same condition, so I understand that as well), but please, make it something that your proud to show to other people. Do actual work on this car, research things before you attempt them. It doesnt cost a fortune to do things right either, I have basically no budget for my cars and I make it work. Its possible. Its not about making the car perfect, or doing it how other people tell you to do it or exactly how they did it, as long as your proud of it that is what matters. I guess all im saying is make the car something your proud of, do work that you are proud of. If your proud of what you have done so far or what this car is right now then I dont know what to say, and all of this may have just been for a lost cause. But thats really all I have to say, sorry if this was really long winded, but I have nothing else to do on vacation right now
Keep going
Eric
Though I like the car, I completely agree with the above. Best of luck! Definitely has potential to be a very cool car.
E30 V8 Build thread
Go here be happy!
Instagram: stuartrussell
I love these detailed posts, keep them up.
No car is a lost cause, but when the car is in such bad shape and you don't have the time to do the things you really want to do, it is really hard to do things the "right way".
𝔣𝔬𝔩𝔩𝔬𝔴 𝔪𝔢
@𝔳𝔦𝔳𝔢_𝔪𝔢𝔪𝔬𝔯_𝔩𝔢𝔱𝔦
exhaust videos and taking it to a car show... that's like ER nurses videoing a critical patient farting blood and posting it on the net... and then dragging the same patient down the catwalk at a fashion show. you guys have great priorities.Hatchbacks, wagons... It's NOT all the same. You want in? Don't get a mazda 3, get a mazda 6 wagon. Don't get a wrx get a legacy wagon. and theres a reason the A3 isn't called the A3 avant... Scion does not make a wagon it makes a weird van, but no wagons
Sincerely,
The Wagon Mafia:Inner Circle
P.S. Is your tail a wagon?
Show cars are lame.
Lol we're trailering it to the show.....Originally posted by Rebounder View Postexhaust videos and taking it to a car show... that's like ER nurses videoing a critical patient farting blood and posting it on the net... and then dragging the same patient down the catwalk at a fashion show. you guys have great priorities.
Nice story though,
wow. as I said nice priorities. way to beat a dead horse. whoring over fixing. lovelyOriginally posted by jrcanes55 View PostLol we're trailering it to the show.....
Nice story though,Hatchbacks, wagons... It's NOT all the same. You want in? Don't get a mazda 3, get a mazda 6 wagon. Don't get a wrx get a legacy wagon. and theres a reason the A3 isn't called the A3 avant... Scion does not make a wagon it makes a weird van, but no wagons
Sincerely,
Show cars are lame.
I understand where you are coming from and I want to start by saying I want this post to come off positively - I'm only posting up in hopes of helping you grow as a car enthusiast and builder.Originally posted by jrcanes55 View PostEverything you said is true.You'll notice though that everything that has been done today (well almost) was in fact to get this pile of junk back on the road. I don't disagree with you. I would love to be able to tear this thing down and make it like new. But that just isn't going to happen. It's not a daily driver and if something breaks there really aren't any repercussions. We're using this car to try things and learn from mistakes we make. For instance I am learning how to weld. Today I did my first caliper install and completely rewired the car (for the fourth time.) Each time I've gotten better. And although cutting springs isn't the smartest thing to do, I learned on this car how to do it the best way. Which I then translated to my E28 which sits perfectly.
You (and the OP... I'm not sure who's car it is and who's doing the work, but you're taking some credit here, so take this as directed at both of you.) need to slow down and start doing work you can take pride in.
We all start somewhere, trust me, I know that quite well. It's great to see your passion lead you into diving in head first in to a project; frankly, you're further along than I was my first time around. I bought an un-roadworthy car with the plans of bringing it back to life, and it never made it out of the driveway. I wound up giving it away.
But with that said, there's only so much credit to be given for the work in this thread. I can't help but feel like everything on this car was done by a couple of meth-heads in a 2-hour stint for reality TV.
Take your time. Slow down. Think your way through a problem and then achieve it. Your solution to everything thus far has been nothing but humorous at best. I know you guys have some ingenuity in you, and you certainly have the drive and motivation to make something happen.
Take that inspiration and spirit and turn it in to something you can take pride in. We all cut corners, and we are all learning as we go, so don't mistake this for a post saying "do it perfect." You guys are just starting out, just like everyone else has.
Things as simple as your switch board:
Just take the time to make the holes straight. Hard work is in the details. I could go on and on about everything done to the car, but I don't think there's a need to do that.
In my eyes, this car isn't worth touching with a 10-foot pole... but if it is something worth tinkering with and learning on to you guys, by all means do so.
But do things you'll learn from. Poor work is one thing - you'll learn from it. But half-assing like everything so far won't teach you anything.Last edited by M.Burroughs; 12-20-2012, 01:17 AM.
well thanks for all the concerns with doing stuff right, i completely agree with you on the quality of work thing, and some stuff will be done legit, but it will never end up restored, if we get petter at welding it will probably end up like the 510 build on here "rusty's Japanese cousin" hopefully when we are ready we will just buy another one (i know of plenty of cheap ones) and start over.
as for taking it to the show being a waste of time, what else are we going to be doing at night in burlington, and honestly it will not be the worst car there, not by a long shot
also Burroughs, i appreciate some positivity, the vw you posted in rusty's build thread is the main reason i got into vw, and that is what brought me into cars, so it is nice to actually get legit insight out of you here
now onto the videos and some updates kinda
click to watch the video, once again should have used youtube
we went ahead and painted the hood black, this picture is the first coat, we did a 2nd of the whole hood but it was dark, today were gonna sand then do one last coat
bleeding the brakes
i actually really like the way that the floors look
driving picture
today we are going to work out a better way of latching the trunk, because the current latch is a piece of crap and needs to be kicked to get it to open, and then is impossible to close
we will hopefully find a new air cleaner, and make an adapter to make it fit or small carb
get the hood finished and back on, then have some time to enjoy the car
