I have some work equips that need new lips! 5x114.3 17". All hardware but lips and center caps! Located far away in Regina hahaha
Something different
Nothing ground breaking in the way of updates, got a new cluster with a functioning temp gauge, and managed to find a non sunroof overhead console case. Brackets are being mocked up for the Recaro install as well.Originally posted by FER86GTI View PostAny updates for this? and what exactly are your plans for this? you should boost it haha.
I have contemplated boost, but the factory trans can't really handle anything above 300 crank HP, And being factory rated at 253hp before what I have done, It would be very costly to safely run maybe 3psi and have a lot of excess weight. There was one intrepid that ran a single turbo on his 3.5 HO, from what I read on the forums he pushed like 5 psi on a daily basis and he gave up on the car after his 15th transmission over the course of 3 months.
Not saying boost is completely off the table tho, Porsche uses a very similar idea when it comes to engine / transmission layout. Both are transversely mounted, and it has been talked about on the intrepid forums, but the thought of paying for a porsche transmission is usually the point most walk away, but I really like the idea of having a manual transmission. That idea may come later as it would require a full rewire and a stand alone, so boosting would make the most sense to do after that.
I seen those!! I had contacted you about them for my GF's koup lol I am thinking I want to stay with 18's and go wide.Originally posted by dubs&boost View PostI have some work equips that need new lips! 5x114.3 17". All hardware but lips and center caps! Located far away in Regina hahaha
Looking at these:
In a mild 18x10.5 et15
And really starting to consider a custom air set-up. But to be a low static intrepid on coil overs would be cool too, either way, be one of the first if not only low low intrepids
Since there isn't much in the way of 'on-the-shelf' parts, everything is a look it over 1000 times and try to figure out a way to make it work. Once the weather warms up I want to hit up Buck's in Saskatoon and maybe walk thru Amigo's as well and see what I can find that I could make work.
Volo In Timore
So progress is slow atm.
Car is seeing daily usage because my truck needs serious work (cv axles, shock, ball joints and possibly an engine) and I am soon changing jobs to a job that will pay me double what I take home now. As soon as I can afford more parts I will be making a few more upgrades
Volo In Timore
Originally posted by baggedb16sentra View Postthis looks amazing, your photo to me anyways looks like a front end for a camaroThanks! As money starts coming in, I will definitely be looking into running wide and low. Going to try my hand at making a set of coilovers from an old set of struts, and if it works out I can always buy new struts to have 'some' ride comfort lolOriginally posted by 244Brick View PostNOW you're talking! yep only 1288 shipped
Just a question of tires. Not sure I want stretch, but to be wide, low and meaty would look cool on a big old grandpa car lol
Volo In Timore
R.I.P P.WALKER 2013/11/30
Dang, I read through this whole thread hoping you'd have it lowered by now. I do like that you've got an unpopular car, please don't give up on this!
It is lowered on the only aftermarket available lowering springs lol, did drop it 1 and a quarter inch. Has settled a bit since the last pics but the weather hasn't been to friendly (Canada re: still winter till July at this rate) so getting better pics is still on the to do list.
Volo In Timore
