520I E28! My first bmw ..
  • #76
    • #77
      Hi!
      To weld the airlift strut would you best consider TIG or MIG welding?
      • #78
        Originally posted by zblex View Post
        Hi!
        I'd say that TIG would be ideal, but MIG is totally sufficient as long as you're settings are right and you are getting good penetration on both metals. If this is your first time welding, have someone experienced do it.
        I recently used pretty much your exact setup to bag a BMW Bavaria and we MIG welded everything and it turned out completely fine. The welds aren't as pretty as TIG welds would've looked, but they were plenty strong and have had no problems yet. Good luck!
        --Golden Boy E30 Build--
        --Etsy Shop--
        --@ayyyitsmikey--
        • #79
          ok thank you!
          Is it possible to keep oem upper strut mount instead of using the ones in the kit? or the oem ones won't be enough tough?
          • #80
            No you can't use the stock upper mounts, because the way the struts are design. They're only designed to be install as given. If you don't use the washers and hardware the air bag won't seal. I have the same bags, but the 75559 no adj Hi Damp
            R.I.P P.WALKER 2013/11/30
            • #81
              Ok thanks
              • #82
                Nice car! looking forward to se it with bags!
                Cant wait too get my bags on my project looking good
                • #83
                  I'm gonna let the car unused for a week... what's the best? Laying frame or standard height... or it don't matter at all?
                  • #84
                    need to see some progress.... also what BMW is color is this? Royal blau by any chance?
                    • #85
                      merveilleuse voiture
                      any update for the bags?
                      you have to lay this frame on the ground
                      Build ---->
                      http://www.stanceworks.com/forums/sh...ad.php?t=34795
                      • #86
                        • #87
                          • #88
                            WOWWWWWWWWWWWWWWWWWWWWWWWWWWWWW that came out way better than i thought!
                            • #89
                              tuffff!!
                              Mx73 Cressida Build check it out!
                              http://www.stanceworks.com/forums/sh...ad.php?t=59875
                              Ig: Japetto516
                              • #90
                                damn that sits nice. i need to get on this level with mine.
                                gimme a sec (e28 build)
