520I E28! My first bmw ..
  • #61
    Sympa ta E28 Renaud, j'ai une petite question, en ayant coupé tes ressorts, tiennent ils encore en place quand tu la lève ? J'ai un projet sur cette base et je pensait a cette solution provisoirement aussi.
    Merci de ta réponse, au plaisir.
    My VOLVO 855
    http://www.stanceworks.com/forums/sh...ad.php?t=37278
    • #62
      translate : Renaud, your E28 is nice, have a little question, did the cuted springs still remain in their own place when you raise the car from the ground? I'll probably do the same on an e28 project.
      Salut, c'est pas ma caisse, mais celle de Zblex... mais on a bricolé dessus ensemble. Pour répondre à ta question, NON les ressort ou ce qu'il en reste ne restent pas du tout en place si tu lève la caisse, à tel point que pour la reposer il faut une personne qui baisse la caisse et une autre qui maintient le ressort au bon emplacement...
      translate : Hi, that's not my car but Zblex's... but we worked on it together. To answer your question, NO, the spring does NOT hold in place when the car is raised from the ground... In such a dramatic way, that when you want to lay her back on its wheels, you need 2 persons : one that control the trolley jack and an other one who is maintaining the spring in its place...
      cheap bagged 190 benz http://www.stanceworks.com/forums/sh...highlight=190e
      • #63
        Thanks for the response ;-)
        My VOLVO 855
        • #64
          • #65
            • #66
              Ahah i love your E28 !
              • #67
                • #68
                  Looking good
                  My E36 build thread
                  • #69
                    Originally posted by zblex View Post
                    What wheels are those? I've been trying to figure it out.
                    • #70
                      Wheels are gotti G1001 17" 3 pièce..
                      • #71
                        • #72
                          classy pic
                          • #73
                            • #74
                              • #75
