Normally, Miata's aren't my thing. But I love this. The rear diffuser looks sweet!
Shumai
1989 Chevy Camaro RS | 1981 Mercedes 500SE AMG
Originally posted by Skraight.And don't let the **** from the guy above get to you, he said he is saving up to buy a del sol lol.
Got bored and plastidipped my door sill. Cut out the raised portions to expose the original black. Now I just need to find some tan floor mats so I can dye them red, either that or find some generic red carpet and cut it the same shape as my oem floormats. Not sure how dye would hold up to everyday driving, not really down to have any red dye rub off on my shoes
So my homie stephen had some universal side mount brackets laying around and we used them to install the recaro's.
We decided to install passenger side first because if we couldnt get it installed on the driver side then atleast I could still drive home. But as you can see from the photos, they sit way too high. Compare its height to the stock seat's height.
If I take out all the seat cushion I will sit at stock height, which is super uncomfortable. We used oem rails + universal side mounts. I was thinking of just bolting them straight to the floor, but what would I need to do this? I'm not looking to spend another $250 (approx) to make custom low rails
The good thing is that it clears my door panel
Here is my car with 1 recaro seat installed.
Got the brackets installed today onto the recaros.
They sit way lower than my side mount brackets + oem rails.
Very high quality, a little bit pricey but I wouldnt hesitate to purchase again.
How it was previously mounted. Universal side mount brackets on oem rails
Ground clearance before
Ground clearance after
Mounted into the car
Seats sitting below roll bar now
If you look back at my other photo when it was still on the oem rails, the top of the seat would be parallel to the top of the roll bar. Now it is well below the main hoop, atleast 3-4" lower than it was before. Definitely sitting lower than stock. I can even go as far as cutting out some foam to get even lower, but where it sits now is a good height for me. Finally glad to have it finished, took atleast 4-5 hours to mount it in the perfect spot and multiple trips to the hardware store to get longer bolts with spacers etc
