purp like cherry cola
  • purp like cherry cola
    hey all this is my S13 "51URY" it cost me too much to buid but i love it and it skids hard..
    spec are these
    Engine -
    JE Pistons (+20 Thou)
    JE Rings
    Nitto Rods
    ACL Race Bearings
    ARP Head/Main Bolts
    GTI-R Oil Pump
    Tomei Sump Pan
    Cometic 1.0mm Headgasket
    BC Step 2 Camshafts
    BC Titanium Valve Springs/Retainers
    BC 1mm Oversize Valves
    Valve Guides
    Extensive Port and Polish (In/Ex)
    New Water Pump
    Tomei RAS
    Tomei Cam Gears
    Nissan Rockers
    Precision Lifters
    Enduratech Timing Kit
    Crank Balanced/Linished
    Powerbond Race Harmonic Balancer
    Intake/fuel system
    Greedy intake plenum
    1000cc Id injectors
    Top feed fuel rail
    Turbosmart fpr
    Denso intank fuel pump
    Bosch external 044
    Flipped intercooler with shorted piping
    50mm tial bov
    Turbo/exhaust
    6boost twin scroll manifold
    Gtx 30/76 twin scroll .82 rear housing
    2 x tial 38mm external gates
    Custom 3" dump and screamers by fabulous fabrications
    Super made VIP cat back system
    Cooling
    55mm pwr radiator Twin thermos
    Pwr intercooler
    Oil cooler with oil filter relocator.
    Driveline
    Npc hi torque organic single plate clutch with 10" flywheel
    Z32 5speed manual
    Ets sr to z32 adaptor plate
    Custom tailshaft
    Nismo 4:11 2way LSD
    R33 gtr drive shafts
    Suspension
    Bc 8 6 spring rate coil overs
    Megan racing fully adjustable
    Camber arms
    Traction arms
    Toe arms
    Tie rods
    Rack ends
    Castor arms
    Z32 front lower control arms
    Carbon front and rear adjustable strut braces
    Wheels
    Work emotion xt7s
    17x9 +17
    18x9.5 +12
    Aero
    Dmax type 2 kit all round
    Origin boot lip and roof wing
    Interior
    Stripped
    Sparco buckets on bride lowmax rails
    Sparco harnesses
    Depo racing gauges
    Nardi wheel
    i have whiteline rear sway bar to go in aswell as a s13.4 rocker cover and a revised catch can set up....
    currently make 315 on pump 98 run in tune, going to e85 power tune next week should get another 100 or so out of it...
    Ended up making 487 on e85 @ 21 pound of boost
    Instagram @51URY
    video of the first run i had in it a few months ago. ENJOY
    [ame="http://www.youtube.com/watch?v=hiZaNy8cIo0"]51URY S13 pt. 1 - YouTube[/ame]
    Instagram @51URY
      currently its in a few bits and pieces changing things to help with reliablity and just a check up from the shake down...
      more photos
      Instagram @51URY
        I really like this car. I love stinger pipes so much.
          well alot has changed with this car since i was last on here!
          car has had a full respray now also rocks a supermade body kit
          full tube front end and a ls1 conversion
          new wheels and alot more low!
          Instagram @51URY
            Instagram @51URY
              Instagram @51URY
                Instagram @51URY
                  Dem exhausts
                    cherry cola isnt purple....
                    car rules though
                    @DollaDollaDill
                      Cherry cola may not be purple but its still delicious. This car? Sweetness. Kinda like cherry cola actually.
                      Sup. Call me Z.
                      My Accord "build".
                        i feel like the thread should have been called "purp like grape fanta" or something
                        because lets be honest your car is almost the same colour as the can
                        super clean though
                          mmm grape fanta.
                          that colour is amazing and loove that exhaust
                            For some reason my photos of the car with the old paint job have gone and it was the same color as the cherry cola can haha hence why the name at the time, will have to change it when I get to a pc
                            Instagram @51URY
                              Instagram @51URY
