Saving a Porsche. Vr6 Turbo power
Originally posted by white out View PostPlease tell me you're throwing a Wevo shift knob into the mix.
Started the wiring on engine side. Almost done and should be nice and tidy now.
Also the RS carpet kit was delivered today and damn are there a lot of pieces haha
If you're ordering custom adapters, call 775.530.2483 to make sure you are getting exactly what you want. Thanks
follow on IG: eurotrashapparel
a little birdy told me that this will be going to paint like very soon....like maybe this weekendsigpic
"how do you drive that? Does it have those lifter shocks on it like the low riders?"
-Faithful Autozone Customer
Make me insta famous @isupa_shaun
Originally posted by tylerlb View PostWhat size techflex did you use?
Ok so had windshield removed before paint and was dreading the potential rust spots. Not to bad at all.
Cleaned it up
Por-15 for future protection
Should be good to go.If you're ordering custom adapters, call 775.530.2483 to make sure you are getting exactly what you want. Thanks
Was making good progress buttoning up the motor install when this happened
Luckily they sell replacement solenoids for $40 and found one local the following day.
Now just waiting on alternator to come back. Since I had the cage powdered I figured I'd have it rebuilt just because.
Tried to fire it up but no spark. Getting a crank position sensor code and a ohm reading out of the range the Bentley suggested so I had to order one of those. Everything else checked out.If you're ordering custom adapters, call 775.530.2483 to make sure you are getting exactly what you want. Thanks
