Lol Hey man it's your car, you're my buddy so I'd like to see you pay attention to areas that need it. More power to you if you go through with it, but I'm pretty sure you can mod the pan to work.
Five- oh swap into an e30.
Originally posted by Jesus Christ View PostLol Hey man it's your car, you're my buddy so I'd like to see you pay attention to areas that need it. More power to you if you go through with it, but I'm pretty sure you can mod the pan to work.
E30 V8 Build thread
Go here be happy!
Instagram: stuartrussell
Originally posted by Jesus Christ View PostThats a very expensive way to get clearance. That's like getting MSD coil over plug setup cause you have bad spark plugs. Vw guys have been modding pans and pick ups for ages, and it's 1/15th the cost
Originally posted by Kielan View PostIf anyone knows about pan clearance on this forum it's Byron.
Pussy, bring it.
This. After seeing what Swoops has done for pans, I'm convinced that inexperience is what the problem is here.
Originally posted by FunfGang View PostI'm not arguing with you! hahaha, that's why I was asking for any help or suggestions. I just don't know what oil pickup I could use if I did cut it out.
^That is the pickup I'm using, theoretically, I could cut a bit out, then re weld it? It wouldn't be a drastic change, but it would prevent the pan from sitting on the plate as it is currently doing.
Either way, this won't happen for a while but thanks for the help Jaze! I'm amassing some small parts here at college, so I'll upload pics as I get them
E30 V8 Build thread
Go here be happy!
Originally posted by FunfGang View PostTried to modify a stock pan, didn't work so well. So bought one from e30v8.com(same pan, pre modified). And wait, the lowest part of the pan sits that high? There's no way.
And that was the plan, but I need to run a hard line for oil pressure, figure out why the alt doesn't always charge, various other things and have the cage built before the second semester of school(when I'm bringing it with me) so I don't think it's happening this year :/
His car is pretty much all E30V8 parts, so I'm sure yours would sit the same if you used the same pan as us. I had to cut his pickup tube and raise it 7/8", but it still hung below the pump itself so there's plenty of clearance there. It still holds 6.5qts too.
And I'm totally copying your exhaust setup for his car btw haha
Originally posted by Byron View PostHe had the E30V8 pan before I believe, does yours have kick-outs on the sides? This is the only picture I have of his old one, he had smacked it quite a bit at this point and it dumped all 8 quarts all over my shop floor overnight.
I may have to get a road race pan, like this one
ROUSH Authorized Dealer in Houston Texas. Ford performance and tuning specialists. Superchargers. F150 performance. Mustang parts and service.
And oh yeah
I'm continuing out the front valance too, when I get the chance.
E30 V8 Build thread
Go here be happy!
Originally posted by Byron View PostDamn, that looks just like the one I modified lol. What motor mounts are you using? I swear his is as high as I sayI'm using the e30v8 mounts, they're the newer style, but same dimensions as the older ones. And them polly m20 mounts.
E30 V8 Build thread
Go here be happy!
Holy cow, really? They're over 1.5" taller!? I don't see how the engine even fits... I honestly have less than 1/4" clearance to my hood in 2 places
E30 V8 Build thread
Go here be happy!
Originally posted by Byron View PostDamn carbs.
If it really sit's as low as you said, there must be a shallower stock front sump pan...
E30 V8 Build thread
Go here be happy!
Thanks! That was my main concern about doing it...
E30 V8 Build thread
Go here be happy!
