Five- oh swap into an e30.
  • ummmm escuze me. update. prease.
    Anthony, Vancouver Canada
    1990 Nissan 240sx Daily driver
    1990 Nissan laurel [Never ending project]
    • what went bad now??
      • I have a 302. In my e30. That is the problem
        E30 V8 Build thread
        Go here be happy!
        Instagram: stuartrussell
        • Originally posted by FunfGang View Post
          IG: Nick475
          • I blame carbs for all my small-block problems.
            I'm usually right.
            - Bagged '98 Chevy S10 - Stock '88 Volvo 240DL - Broken '87 Mitsubishi Starion ESi-R - Also Broken '87 Shelby Lancer #707/800 -
            • I want this but with SBC.
              We Fuck Shit Up
              Shit box Sketch10 burnout truck.
              • Originally posted by Daviticus View Post
                I'm usually right.
                Not this time.
                Do it
                Also, lots of work and no progress, I'm currently pulling the engine for a new one. I probably won't even look at this thread until I'm done, let alone update it, so if you want to follow it, my hipstergram name is, "stuartrussell". Creative, I know.
                E30 V8 Build thread
                Go here be happy!
                • Wait so your engine is bad? No. NO NO NO
                  Also, my buddy has an e30 and wants to run 15x9 et0 shakotans, didn't you run that setup? How was the height/ride/scrapeage and what tire size did you run?
                  • Originally posted by willis View Post
                    Funny story, that engine sat for 10 years, but still turned over and had compression, and now it decides to seize. And yeah, I did. I'll shoot you a pm!
                    E30 V8 Build thread
                    Go here be happy!
                    • Wait... you think your engine is bad after all of this?
                      If it cranked over before, you might have missed something! Check your starter, get it to crank at least!
                      Originally posted by Ollie
                      • Originally posted by MommysLittleMonster View Post
                        New starter, tried turning it at the crank even, plugs out and everything. Wont turn. Both starters extended, hit the flywheel, tried to turn and it just won't budge.
                        E30 V8 Build thread
                        Go here be happy!
                        • IG: ossiep
                          • New engine will be in this weekend!
                            E30 V8 Build thread
                            Go here be happy!
                            • vov. nice...
                              then i was
                              WOW NICE...
                              then i was...
                              HOLY HELLLLLLL.............. 8)
                              • I take it you checked for proper grounds and voltage.
                                Pull the plugs and fill the cylinders with a couple ounces of one of the three things:
                                Pb blaster
                                Crc freeze off
                                Diesel
                                Let sit for a day or two, hand crank to liking, then blow it all out with the starter.
