94 Turbo Saturn (pic heavy)
  • #16
    Originally posted by Haggard_guy View Post
    good build. there is a guy in my area that has a pretty sweet one.
    holy shit. more info/ link for a build thread on this thing?
    Allen
    flickr / Twitter/Instagram
    • #17
      A few of us saturn guys tried to get more info on the car, but couldn't really find anything.
      94 Saturn SW2 - T3s60 7psi, slammed, daily driven
      94 Saturn SC2 - T3/T4, 13.4 @107 mph, built motor coming soon
      --MegaSquirt user--
      • #18
        Small update, I have finally been getting back to the car and dosing some reassembly under the dash. I streched the last bit of wires needed to relocate the fuse box to the passenger's side of the dash. I still have to actually get it mounted, but I at least know where it's going and that it does fit. Got some of the climate control stuff put back together, but it's a little tough with broken hip to move around too good. I also removed the headlight assemblies to make painting the engine bay easier and I also want to get the headlight brackets cleaned up and painted since they're getting some corrosion here and there.
        As far as the wagon goes, I'm going to give the car a good wash and cleaning this week for the big TristateTuners meet next weekend. I'm also hoping to install the new ACT street disc clutch kit so I can instal the 7psi spring in the wastegate. The car moves pretty decent right now (should run high 13's in the 1/4 mile), but I know it'll really get out of it's own way at 7lbs of boost.
        --MegaSquirt user--
        • #19
          Love oddball builds like this! Keep it up
          E30 V8 Build thread
          Go here be happy!
          Instagram: stuartrussell
          • #20
            Info on that black one on 527's, when I saw it at the last local car meet, he didn't have a hood and I immediately noticed he was using nuts to space out the top hats (just like that "loud and low" civic kid) I chuckled to myself and walked away.
            IG/TWITTER @alloydhiggins
            • #21
              Oof, well I have no plans to do top hats in that manner. If I do them, it will be on my wagon I would do them properly. I like my cars to be safe no matter what so I try to never cut corners to make something work like a lot of people do.
              I'll have to update this post with pics, but I pulled the headlight assemblies out (PITA) so that I can clean them up and paint them since they've gotten some corrosion on them over the years. I'm hoping to color match the bezels around the headlamps and leave the rest of the assemblies black to look factory.
              On another paint note I think I decided what I'd like to do with the engine bay scheme. I'm going to color match the bay and buy some gold paint to match the wheels which will get sprayed on the valve cover, engine block and probably a few misc items. Everything that isn't getting a gold or brown splash of paint will remain black or silver polished. I can't wait to get down to work on the car once I'm better enough to get some real stuff done.
              --MegaSquirt user--
              • #22
                Unique build :thumbup::thumbup:
                • #23
                  pretty rad, keep it up!
                  • #24
                    I'm inspired by the fact that you took such a random car and put so much work into it.
                    • #25
                      Thanks guys!
                      I have been able to pull the headlight assemblies apart over the past few days and I got one all in primer. I'm going to try and color match the bezel around the headlight and leave everything else black.
                      --MegaSquirt user--
                      • #26
                        Making necessary modifications to the intake. Since it split along the bottom where the pipe was cut apart and welded I'm going to have it sand blasted, welded properly, have a new water oulet fabbed up and use a coupler to hold the two pieces together. Now I can adjust the angle where the throttle body sits since I'd like it to run under my rad hose as it used to be angled up above it.
                        I've been doing more work here and there, the dash is back in the car and most of the wiring ran, and I've decided that since my friends are slacking that I'm going to throw the drivetrain back in to get the car running and moving before the bay gets painted. I'll just pull it back apart in the spring to get that finished.
                        --MegaSquirt user--
                        • #27
                          Hey jusst ran across this thread hope its not dead but where did you find the parts for the saturn because im having a tough time finding aftermarket parts
