Fiat 128 Berlina 1100
  • #16
    FIATs <3
    • #17
      this thing looks awesome!
      • #18
        Testing the fitment 7x13 ET20 with 21mm spacer front and 16mm rear
        • #19
          New wheels look awesome, cant wait to see pictures
          • #20
            I know the stance you are going for but damn this thing would look so good slammed.
            -Aron
            "Living life a quarter turn at a time"
            • #21
              I'm going for 185/60-13" R888 next, track day stance. It will look kinda more slammed hence the higher profile.
              • #22
                that looks great, sweet little fiat!
                • #23
                  • #24
                    this is awesome. its like an italian 510.
                    1989 Volvo 240 turbo
                    • #25
                      I look seeing these Fiat's getting some love.
                      Instagram: "Cole_Lenhart" Out of Thread Builds Shoots and Progress
                      Just a Truck Build: "Here"
                      • #26
                        Here is the engine I've built
                        Uno 1400 head with 37.5/31 valves, throated bowls, ports 29mm, bigger long side radius, enlarged combustion chamber to suit big bore, deshrouded valves etc.
                        Block Uno 1500 with OEM forged rods
                        Domed pistons Delta 1300, rare item
                        Delta 1300 pins,23 grams lighter per unit also rare item
                        Abarth 214 camshaft that is probably 40-80 with around 10.5mm lift, soon adjustable cam pulley
                        Twin 40DCNF Weber
                        Lightened flywheel to 3900 grams
                        etc.
                        Exhaust valves 1100 unit,5 grams per valve ligher, better flow
                        I lost about 1kg rotating parts in lightest OEM pulley combo that I can find.
                        OEM forged rods that are 8mm longer are 30 grams lighter per unit than the stock shorter rod.
                        With unadjusted valves and without exhaust
                        [ame="http://www.youtube.com/watch?v=7JOCsO2-IxQ"]Ventili lupaju o deklo - YouTube[/ame]
                        • #27
                          Sweet Fiat man! I agree it looks like a 510, How much HP do you think you will you be pushing with that rebuild?
                          the VW community is weird. dont try to understand, its like understanding africa.
                          Instagram: bigslowchevy
                          • #28
                            I reckon about 100hp + -
                            • #29
                              That should be pretty quick for that car, What does the car come with stock?
                              • #30
                                sweet project
                                Floccinaucinihilipilification
