Walter the wagon
  • #16
    Waiting for the mounting of that engine !!
    • #17
      I wanted to wait till after the new year, but I am considering throwing it in this weekend. I have everything needed for reassembly, but I need the following before it can run:
      5mge oil pan/pick up (from my current motor), have to tap the pan as well for the return on the oil cooler.
      Swap mounts from old motor
      One more knock sensor (PO broke it having the motor sit)
      Oil cooler / lines
      30 feet of new vacuum lines
      FMIC/piping
      Wiring harness in good shape
      Modify harness to be plug in play with my chassis harness.
      then live rear axle slides around corners!
      • #18
        Sweet Cressida bro, cant wait to see the engine in.
        the VW community is weird. dont try to understand, its like understanding africa.
        Instagram: bigslowchevy
        • #19
          Originally posted by electricalbox View Post
          LOL relaibility FTW!
          I modded my 08 GTI, but I want something old I can wrench on and not be financially damning. I have had tons of cars, but this wagon will fit all the needs I have been looking for with all the others. Also planning to sell the GTI so I can put more on a downpayment for my house.
          Yeah, as long as you're sure the ol' Cressida is reliable then go for it!
          StatusRacing.com
          Configure YOUR Seat Here
          Tel: 1.480.265.8600
          Email: sales@statusracing.com
          Fan us on Facebook
          • #20
            Helicoiled some of the studs yesterday...one doesn't hold, looks like they tried it before. I threw some jb weld in with the helicoil and left it overnight. Here is to wishful thinking...
            Was going to install the digital dash today, but I am going to check out some wheels on my lunch, don't think I will get much done in the dark, but we will see tonight.
            • #21
              If this wagon were a boxer, it would be competing in the walterweight class.
              ...I suck at jokes today.
              Love the build though! Keep it up!
              www.fluidmotorunion.com
              www.stanceworks.com
              Originally posted by Oxer
              • #22
                oh this is nice.
                Expect problems and eat them for breakfast.
                • #23
                  Love the wheel rack! Im about to build myself one this weekend. Awesome wagon as well
                  Follow on IG
                  amgwheelwhore
                  Buy my wheels
                  Vintage AME Wheels
                  RUF Speedline Wheels
                  Buy my cars
                  W115 & W123
                  • #24
                    Picked these up on my lunch break, not much to get specifics, but I will have more updates later. Appear to be 4x110 16x7/8 et20, planning to run 30mm adpater making them et-10.
                    I lol'd, and I will use that now.
                    Originally posted by hetzyhetz View Post
                    oh this is nice.
                    Thank you sir!
                    Thank you, it is quite easy and fulfilling to build it yourself. If you have any questions lmk, but my design is pretty striaght forward. Just FYI I used joist hangers and on the middle two shevles I didn't screw them in (just resting on the hangers, but very sturdy). It allows for easy removal on larger wheel/tire set ups.
                    BTW here is how I did it for others:
                    In total for wood I got 6 2x4x 8' and 2 2x3x8. Two of the 2x4 and both 2x3 were cut in half to make the rows (4'). The other four 2x4x8 got cut into 2x4x6 leaving four 2x4x2' (two left as is and two cut into the four needed 2x4x1').
                    It is not to hard, side frames are just 2"x4" x 6' with 2"x4" x 1' centers. Build these two and put a 2"x4" x 2' on the bottom to keep it up in the air. On the ends facing inward add joist hangers every 24" apart starting with the first as low as possible (top is only 20 IIRC). I used 2x4" x 4' on the top/bottom connecting the sides and 2x3" x 4' for the middle two shelves. The 2x3" are removable and just sit in the hangers, while the top/bottom 2x4" are permanent and screwed in. The top row the joist hangers are not 12" apart, but 10" to help with balance.
                    These measurements make each storage are 2' / 4' wide / 12" deep. Since the of the sides has 2x4" x2' it adds 2" lip on the bottom and keeps the wheels from touching the wall out back. Overall dimensions are 6'2" tall, 4'2" wide, 2" deep.
                    • #25
                      Can anyone ID these, they have no embossing/engravings. Measurements are 16x7/8 et18 approximately; PCD appears to be 4x108.
                      Dirty wheels FTL:
                      Cleaning them up:
                      Yay for reverse-mount I didn't have to break the seal:
                      Remember to always clean your nuts.... and bolts:
                      • #26
                        Step dem lips. Cool looking wheels though. And i do love toyotas. Keep it up brah!
                        ohai there
                        New Zealand thread: http://www.stanceworks.com/forums/sh...ad.php?t=22785
                        • #27
                          Thank you sir, yah I am debating going bigger on the wheels, problem is sizing everything up. I don't want stretched tires on my wagon, and the wheels are 16x7 (1" lip) 16x8 (1.5" lip) et18 all around. Since they are 4x108 I will need adapters since I don't want to redrill, this will make them et -10 all around which will look nice.
                          • #28
                            I had a set of those, I think they were primes but the cap said HR. The markings on the rear matched my prime RS copies. Nice with them being three piece.
                            Activity is not on my list of activities.
                            • #29
                              This looks promising!
                              • #30
                                ive been looking for a cressida wagon high and low and cant find any for sale good build
