hmmmm from my experience with black cars you ahve to repaint the entire care when you do that..... look ok in the pics so far
the legend of one low cobalt
he did the whole panel so at least it matches.
better pix now!Originally posted by M.BurroughsI'd have to say this site was founded on building the cars we wanted to build, despite if the rest of the car community liked it or not. This site was founded on freedom of automotive self expression and the passion that goes in to each and every build... This site is about doing what you like, whatever makes you happy, and not caring about what other people think...
That rear camber is a bit much for my taste but those wheels do look good on the car! Also I am glad to see the paintwork done right. Keep it up!
...and I'm with the guys that say that your basic black is easy to match. I've had a lot of paintwork done on my daily and never bothered with a paint code.
It'd be cool to see a shoot of this car with the silver Ion Redline on 'vette sawblades (although in reality I don't know where you guys are located in relation to each other). Do a feature and call it "Delta Stance" (or something probably much better than that).
this car has already been rear ended, used dupont 99k base and always have been. never had a problem blending panels.Originally posted by Vegas13 View Postthats not the whole car. doors, hood, front etc
this weekend my friend!Originally posted by jared1988 View Posthe did the whole panel so at least it matches.
better pix now!
i have spotted that car before and he's just not really doin' it like this. not really into it, but hell i mean my cars love it or **** it too.Originally posted by lilcraigford View PostThat rear camber is a bit much for my taste but those wheels do look good on the car! Also I am glad to see the paintwork done right. Keep it up!
no :3Originally posted by staytuned05 View Postjust a lil too much camber for a small wheel, can u get smaller spacers maybe?
and one of my favorite things to do is drive 2 hours to philly just to check out the graffLast edited by ff_drift_lol; 12-04-2010, 11:51 AM.
my coils are retro fitted. they are megan racing coilovers from an acura rsx or civic ep3. the top hats are from the civic as well, so i drilled pilot holes in my strut towers and used a step bit to get the size nice and mint (besides using a step bit is a breeze). that was tough. the ears will match up with minor honing to the holes, step bit again. but since i got mine after they were in an accident, i cut the existing ears off and welded cobalt strut ears on the megan sleeves.Originally posted by soderdna View Posthand's done hottest delta ive ever seen. Ive got an 06 pursuit so i know your battles to get one low. Im still working my way down. what coil overs do you recommend? Im on sportlines right now
here's what I did:
megan 32 ways 12k rate from a civic ep3, one got hit. friend didnt know what to do, so he gave them to me for 250 bucks.
took mounting tabs from donor struts
mig welded
as of right now, i have an fe1 sway bar to compensate for all the understeer a 12k spring would give me on this car (they're normally 8 or 9k on cobalt coilovers) since they have a longer wheelbase meaning more understeer. so the end links are attached to those steering knuckles on the coilovers you see, bolted a nice 1/4" steel L bracket and bolted the end links into those. gotta get some pics up of that.
as for the rear, i am on cut progress drop springs, which is why i was having the rubbing issues. once i get coil over spring adjustable coilovers for the rear to replace the shocks and delete the coil in perch springs (solid rear here) then i can drop the car more without worrying about buckling my quarter panels again. i still have a ton of subframe and oil pan clearance in the front.
another issue is my axles do not like the angles. they vibrate under high torque and i'm working on raising the engine to compensate for this.
the point of this post is, anything can be done with time, dedication and a little cash.Last edited by ff_drift_lol; 12-04-2010, 02:01 PM.
Not quite true.Originally posted by Vegas13 View Posthmmmm from my experience with black cars you ahve to repaint the entire care when you do that..... look ok in the pics so far
Blending the color itself is pretty simple if you know the techniques. Some colors are tougher than others, especially when it comes to metallics and pearls, but it can still be done.
Clear on the other hand should not be blended. It can be done, but usually withing 6 months it is easy to see a panel that has been blended.
Anyways, the car looks good, glad the body work turned out good for you.
