Please remove roofrack <: As much as I enjoy the ratty look on these aircooleds, the new style roof rack is ruining the Ghia's nice lines man!
Ratty Ghia
if you respray it...keep the blue and white, flat black would ruin it
some smaller tires will help you out as well, and a drop beam....you can drive these slammed without airMy super boring build http://www.stanceworks.com/forums/sh...other-M3-buildInsta Mintyhinrichs
this sums it upOriginally posted by hinrichs View Postif you respray it...keep the blue and white, flat black would ruin it
some smaller tires will help you out as well, and a drop beam....you can drive these slammed without airFloccinaucinihilipilification
I dailied my Ghia right up until I took it off the road for resto. 3 splines without extended spring plates means that you have to be prepared to flip your rear tyres every 400'ish miles (replace every 800ish). Ghias go can look fucking low, while maintaining fairly good ground clearance as the jacking points and drip rail things on the sills are the lowest points on a K&L Ghia... Although, you're Balljoint so it'll be a bit harder.
totally forgot about the extended arms, if you get those you will be a lot happier
start reading up on thesamba and youll learn alotMy super boring build http://www.stanceworks.com/forums/sh...other-M3-buildInsta Mintyhinrichs
058 by the1theycallt, on Flickr
061 by the1theycallt, on Flickr
060 by the1theycallt, on Flickr
059 by the1theycallt, on Flickr
062 by the1theycallt, on Flickr
063 by the1theycallt, on Flickr
