Got the G in May and swore to myself that I wasn't going to mod it. Then some asshole in my old apartment complex hit my car and it kind of lost the new car feel so I said fuck it, let's go. The next day I picked up a set of wheels and ordered some coils.
Wheels, Vellano VSMs 20x11 et25 and 20x9.5 et15:
Coils are BC Racing BR Type with 14/12 springs, and the coilovers properly revalved to deal with the increases stiffness of the springs. Installed them and figured I would try the fronts all the way down, and the rears about halfway and this is what I got:
Obviously it needs some tweaking. For the 20s the fronts will probably have to come up some, and the rears need to come down about two inches which won't be a problem. Only problem I've run into so far is that the wheels don't clear the brake calipers on the sport model, so I'll have to run spacer . After spacers the rears will end up at about at et 20 and the fronts will be at et -5, which from what I've gathered is 10mm more aggressive than what has been run before (I might be off, the G forums are pretty weak). Camber arms are in for the rear, and will be needed for the front most likely. Let's make it happen.
