The "what the heck is that" build... LameG60content.
glad you kept the color
white borbets would kill it imo?Floccinaucinihilipilification
Every little bump in the road... The tire rubs inner fender, i didn't want to pull the fenders like most lowered corrado's i don't like that look... but, If I have two people in the car...it's a no go... I bought banchworks drop plates at -5 degrees camber so I shouldn't have inner clearance issues strut to wheel... And I'm guessing with the added track width and camber it should still sit flush hopefully with less rubbing... HahaOriginally posted by G535 View PostLooks nice. How much are your rears rubbing? Suspension travel at all?
Im running ~2,5° camber in the rear, 9x16 ET7,3. Like 5mm clearance between coils and wheel.
I dont like the pulled look either. Still got the fender line but im gonna rebuild it over winter again to make it look 100% oemOriginally posted by CorradoMan1 View PostEvery little bump in the road... The tire rubs inner fender, i didn't want to pull the fenders like most lowered corrado's i don't like that look... but, If I have two people in the car...it's a no go... I bought banchworks drop plates at -5 degrees camber so I shouldn't have inner clearance issues strut to wheel... And I'm guessing with the added track width and camber it should still sit flush hopefully with less rubbing... Haha
You sure those Banchworks plates solve that problem? My wheel sometimes hits my springs...
Also they look like they affect your toe - which will cause tire wear and bad handling..keep in mind that the rear axle is the one that keeps our cars in line.slamburglars.com
Haha, guess we will find out. Based on what I read about the banchworks plates... Is that they are bent to adjust the toe for that much lowering/camber... I guess it's gonna be an adventure. My wheels are a decent amount away from the coil over body from what I remember... It's just the collar that Is super close to the lip of the barrel... If rubbing doesn't stop... 205/40's hahaha that should do it..
