Project DD aka Silver Bullet "400hp with style" Supra
on the ground.. winter dd height.. it doesn't look low.. but it is lol
luckily TheMadSupra has been a super nice guy and let me use his lift a couple times.
so the Occupy lifts movement was a go.
feed line.. -10an with an inline 10,100 micron filters
LOOKS stock right?
get in ma belly
ya thats not a bad idea haha
so i had a little accident with the car last night..
i was in the middle of mounting my return stainless steel return line when i heard a little crackling sound..
the line was drapped under the car and on the engine bay, so as i am mounting i tug on the line to get a little more slack. a minute or 2 later I smell a sour scent in the air and realize that something is burning. i walk to the front of the car and Smoke is Billowing out from the hood. I rush to get the car down from the lift. only to find that the Stainless steel line is arcing on the battery and vulcanizing the rubber. Lets just say its scared the shit out of me lol. luckily only thing damaged was the return line.
I had originally done the same mount as 2jzmk3 and UPGRADEDsupra for my fuel pump, but for this car that will be driven so much.. i just don't want to risk it hitting something
so I mounted it in the spare tire area. Aeromotive eliminator and fuel pump voltage regulator.
it will exit the pump of a elbow and then to another elbow that will be tap'd into the side of the spare tire well ( just like the one coming in )
for some of you who don't know.. i took the 2jz from my white car and it is now in this car.. these are not current pictures. i just now learned how to upload from my iphone lol. so.. boom goes the dynamite.. ill get this thread up to date soon
motor in and shit getting tied up..
sweet ass intercooler support. powder coated and made by Jacob smith
routing the engine harness.. such a bitch when using a JDM supra engine harness because its 18inches shorter.. so you can either lengthen it or.. cut a new hole and reroute it.. i chose rerouting, but it was a huge pain in the ass lol
in through the hole.. right behind the fuel rail (driver side. 1inch below and to the right of the throttle body cable
slide past the pedal linkage..
up and under the defrost vent
then finally droping down in stock location.. althought the AEM EMS does not fit since its much larger.. fuu
–noun
exact or accurate formation, position, or adjustment: to be out of true.
–verb (used with object)
to make true; shape, adjust, place, etc., exactly or accurately
— adj , truer , truest
1. not false, fictional, or illusory; factual or factually accurate; conforming with reality
2. ( prenominal ) being of real or natural origin; genuine; not synthetic: true leather
3. a. unswervingly faithful and loyal to friends, a cause, etc: a true follower
b. ( as collective noun ; preceded by the ): the loyal and the true
4. faithful to a particular concept of truth, esp of religious truth: a true believer
5. conforming to a required standard, law, or pattern: a true aim ; a true fit
6. exactly in tune: a true note
7. (of a compass bearing) according to the earth's geographical rather than magnetic poles: true north
8. biology conforming to the typical structure of a designated type: sphagnum moss is a true moss, Spanish moss is not
9. physics Compare apparent not apparent or relative; taking into account all complicating factors: the true expansion of a liquid takes into account the expansion of the container
10. informal not true unbelievable; remarkable: she's got so much money it's not true
11. true to life exactly comparable with reality
— n
12. correct alignment (esp in the phrases in true, out of true )
Thanks for this man, I was totally unaware of what the word True meant. This has made everything make so much more sense now.
–noun
— n
