teamSPB Project DFN U - 4 SMD 18's 30kwrms, air ride etc etc
  • #31
    Box was resined with 2-3layers internally...
    Then I built this
    teamSPB
    • #32
      very nice! so glad to see someone do stance and system build. very good choice in subs too!
      • #33
        Cheers Jcoleman!!
        • #34
          3 Layers in total make up the front baffles...
          The inner most edge has a 1/2" radius to help air flow at the back of the woofer
          Offering up the baffles to make sure they fit
          The weird cut outs I showed you before, are the braces for the inside of the box as well as the magnets as the subs weigh around 40-50kgs EACH! Not only are the 18" in diameter....they are nearly 16" DEEP!!!! Imagine the leverage weight on that!
          And test fitted with the port
          The back panel was then glued up
          And joint the rest of the box!
          Time to strengthen the top of the box!...An extra 2" of MDF going in
          teamSPB
          • #35
            teamSPB
            • #36
              Oh and look what finally made its way to see its new home LOL
              teamSPB
              • #37
                Time to get the braces in to firstly, support the subs, and secondly brace the box BIG time!
                Get some angle steel (which is rated at over a ton IIRC!)
                Cut it to the right lengths
                Bond it to the wood
                Then screw the steel to the MDF using HEAVY duty coach screws
                teamSPB
                • #38
                  Time to fit the braces!
                  As you can see from the pics, the braces are 2" thick themselves...and are braced further by the steel sections...I dont think this will flex! If it does, ill be in serious shock! Steel/MDF is bracing the side panels, the port, the floor AND the roof!!
                  Port was also specc'd and radiused...
                  teamSPB
                  • #39
                    Time for some pretty panels to be mocked up
                    Then it was time for some flock! MASSIVE MASSIVE thanks going out to Mike and Nikki here...they are awesome at flocking!
                    Only have one photo of it so will need to check my camera to see if there are more photo's...if not ill take some more...
                    teamSPB
                    • #40
                      Damn thats crazy.
                      How many db are u lookin for when its done?
                      I am really broke with far too many ideas.
                      • #41
                        this
                        is
                        nuts.
                        -Updated 07-29-2013- _ padraig@deathsquad.ca _ _
                        • #42
                          Originally posted by Neil View Post
                          Damn thats crazy.
                          Im hoping for around 157-158db fingers crossed! HOWEVER, im not building this for numbers...infact, there is alot riding AGAINST it doing big numbers...the cabin is HUGE...Honestly..the space I have left in front of the wall is probably the same as a Polo inside! Ontop of that, my tuning is pretty low (30hz)...
                          I built this to play music and play it loud...I listen to alot of dubplates so the lows was a priority for me...oh and to be like a wind tunnel lol!!
                          I just want to have fun with the vehicle..play loud when I want...and scare people left right and center lol!
                          • #43
                            making the earth shake- god I love big audio builds
                            member # 1168
                            Originally posted by Deltron
                            fast & furious 6 will just be slammed cars. Brians new job is stealing and selling oilpans. the climax of the movie is when torretto has to get over a speedbump.
                            • #44
                              Sick!
                              • #45
                                haha..cheers guys!
