Das V8 Coupe Quattro
  • #61
    Originally posted by Okin View Post
    I know of a serious VW tuner locally, that is familiar with this set up...
    **cough http://www.briansgarage.com/v3/shop.htm cough**
    Try giving them a ring.
    gave brian a ring, he was on the right tack...but suggested i talk to hoppen in florida or shine racing for unitronic software....well i am a unitronic dealer so no go there. Brian made a few suggestions on my 2x2 dianostic port on the v8 auto ecu. Thanks for link.
    Radiator is mounted but still need to do the coolant lines.
    IG: awscarguy
    '90 Jetta - TSI swapping
    '13.5 Jetta GLI - new daily toy
    Haus of Dub
    • #62
      did you go to DubDash last year?
      Lookin' good man, can't wait to see what kinda numbers this puts down while laying low.
      Follow Me On Instagram! @jvc8790 #jvcphotography
      • #63
        hell yea i love that body style!
        not often u see one of these
        keep up the good work
        • #64
          IG: awscarguy
          Haus of Dub
          • #65
            this thing is awesome....so much fun potential
            Eight individually controllable coil drivers for unequal firing or different cylinder advance
            Eight injector drivers, with individual adjustments, for sequential injection up to eight cylinders or control of up to 16 staged twin injectors
            Amplified Coils Support
            Full 3 or 4 wheel traction control with switchable, on dash, on/off and wet/dry settings
            Launch control with numerous options
            Turn off closed loop above TPS & RPM
            Full turbo anti lag facilities, switchable on dash.
            Logging switchable on dash
            Voltage in warning limits during Mapping
            Manifold Pressure as main load
            Improved idle speed control
            Nine auxiliary outputs for various functions
            Improved, more flexible data logging capabilities
            Compensation for air temp / water temp / MAP or barometric pressure on fuel and ignition
            Closed loop Lambda control
            Full turbo pressure control variable by RPM with overboost protection
            Steering wheel button controlled start line RPM limit
            Full power shift cut
            Temperature dependant idle speed control via PWM valve
            Dedicated shift light output
            Serial output of data for dashboard
            Dedicated Tach output
            Two stage main RPM limiter
            Dedicated fuel pump control
            Full start-up fueling map
            Throttle transient enrichment map
            Self test facilities for ignition and injection
            Diagnostics and peak recording
            Real time mapping, no EPROM's required
            Selectable 20 X 14 lambda target map
            In-vehicle fuel map building
            Can use 5 volt linear lambda sensor with external electronics
            All main 3D maps (20 x 14) have user programmable break points.
            Max. RPM up to 16,000.
            Flexible PWM outputs linked to any input useable for any of the following;
            Water injection (multistage)
            Speed related power reduction (Drag bikes)
            NOS control with fuel enrichment and ignition retard (multistage)
            Fuel Mixture control for endurance racing
            Twin Fuel pump control
            Anything else requiring mixture and ignition control linked to an input and an output.
            cant wait to start wiring this weekend!
            IG: awscarguy
            Haus of Dub
            • #66
              Haus of Dub
              K Sport Precision Turbos Franken Turbo South Bend Clutches IE Rods Unitronic
              • #67
                Damn. Sick build. Love that you're staying with audi on the V8.
                Still like i5 20v moar
                Can't wait for more progress
                flickrrrrrrrrrrrrrrrrrrrr
                • #68
                  IG: awscarguy
                  Haus of Dub
                  • #69
                    little touch to the grill
                    IG: awscarguy
                    Haus of Dub
                    • #70
                      got it
                      IG: awscarguy
                      Haus of Dub
                      • #71
                        Win!
                        "on our way back i hit a bump and both of the springs slip off of their seats and slashed both of my front tires."
                        -Dane M
                        If your not doing this, your doing it wrong.
                        • #72
                          Really interesting build I cant wait to see it completed
                          • #73
                            meeee toooo! well getting ready to head over to the garage to pull the motor for the crank sensor relocation. I have 3 trigger setups, 2 for the old ecu, 60-2 built into the flywheel for DTA.
                            I have till the 16th to get this going. my work asked me to fly to dulles va for 6 weeks to work in AOL's datacenter as HP, Dell, IBM, Sun hardware support as they rebuild the datacenter. will be cool trip, but not cool for car work. No SoWo this year VWoA is right down the road.....who is in the Dulles/Hernden area?
                            new tails for the 200 daily
                            IG: awscarguy
                            Haus of Dub
                            • #74
                              Originally posted by Zic View Post
                              sweet.
                              thats one looooooooong cam belt, and those numbers on the valve are a bit cheating 4dhc - so it has 4 dual overhead cams, like 8cams in total? it should say 2dhc.
                              Not trying to start some flame war, just thought it was a bit funny.
                              if you look beter you'll notice it say's 4ohc meaning 4 overhead cams
                              • #75
                                i stand corrected, my eyes must have failed me Good first post as well, and welcome to stanceworks.
                                -Instagram@jdjurhuus
                                Stretchsaurus and Pokemon.
