Originally posted by Heist
View Post
Heist's Build Thread.
Originally posted by Heist View Postmakes sense. I use the copper on one side of every hole I fill so it keeps the grinding down. Little trick I figured out one day.Originally posted by CubbyChowder View PostHow does it keep the grinding down?
Originally posted by Rains View PostBy putting copper on the back side, the molten metal while welding will be held in place over the hole from the copper piece. Makes it easier to form the metal over the hole
if im correct you cant weld copper, it it mainly used to absorb the heat from welding to help with distortion os panels and such, but it your backing a pinhole your filling you should only really have to grind down one side o the hole if you get a good "seal" with the copper.
ps harbor fright sells this doodad that has come in handy for me.
I use the same method, it make filling slighlty bigger holes much easier.
I used a length of pipe that t hammered flat and folded over a few times, it is easy to bend and shape to fit in tight area and gives a nice handle so you can hold it without a glove.We Fuck Shit Up
Shit box Sketch10 burnout truck.
I've been watching this thread for a while now, but not commented before now.
I must say, you're an crazy crazy guy, with a crazy crazy project, and I love it!
I could only imagine to have those skills you have!
Lookin forward to keep watching you're buildingthread!'97 BMW E39
'92 Honda Civic HB
followed by this
sucks grinding with the wrist so progress might slow a little for now haha
drilling out the holes for the master cylinder on the pedal box and the makita caught an edge. Little sucker has a lot of torque! spun my hand around real good..... and yes hairy monkey arm.
