Those ports look really narrow :/ You probably get a lot of port noise don't you?
bd Project Extra Low
Originally posted by styler2002i View Posthow much would deseaming and smoothing a mk2 golf or a e30 convertible cost.. by any chance.. im contemplating starting a project.. just weighing up costs..
last night we stripped all the dash & front seats back out, ready for a for the hole S3 loom to go in.
S3 loom is now in the car & going the bulk head
Loom is connected up to everything behing the dash, it's all in the right place to see if we have missed anything & it will also help us when we go to wrap & tidy the loom up.
All the loom in the engine bay has been placed where it should go & all the components that will eventually need connecting are placed in the rough area where they will or need to go.
I know I will have problems using the S3 brake master cylinder & servo as there is minimum space between the engine & firewall.
First time we connect diagnostics to the car, read the bottom of the screen
S3 fuel pump connector
Mk3 fuel pump connector
I took the S3 ABS pump off & put the in the mk3 for now it is just sitting in the engine bay connected to the loom so that we have communication through diagnostics.
Ok last night after we had very thing everything connected up & as much of the faults deleted as possible we thought it was time to fire it.
[ame="http://www.youtube.com/watch?v=rjGfRvKQxeE&feature=player_profilepage"]http://www.youtube.com/watch?v=rjGfRvKQxeE&feature=player_profilepage[/ame]Last edited by Bespoke Division; 05-11-2011, 09:22 AM.
A lot has gone on since last up date, the engine is back out again & loom has been re run behind the dash & through the chassis legs. What MISSION that was
I had to get my snap on video scope to see in side the chassis leg, hiding the loom has taken up so much time you wont under stand & what makes it worse is that I am running a lot more in the engine bay than the mk3 set up.
I could of made my life easier & not used or got rid of a lot things like washer bottle sensor, heated washer jets & so on but that would of been to easy
Lamda sensor wires run under the carpet through a conveniently placed grommet under the drivers floor
Spot the fro OH NO IT's TIED UP
Mk3 wiper assembly & motor
The plug is different from the S3 one so this also had to be changed
I have removed the alternator + wire so that I can put a bigger one in for the I.C.E
We found an old inter cooler in the workshop from a 2009 audi A4 2.0 tdi which we fitted an up graded one to, so I know this one is mint.
Placed it under the mk3 slam pannel & it looks like it could work
All I need to do now is trim the front bumper reinforcer mount it & see if I can get some inter cooler pipes & silicone hoses to it I some for my subaru which are blue which I will use on here for now & then get something a different colour later, may be white or black ?????
I didn't end up finishing the car for the blitz, I was tired & we had loads of customers that turned up Friday & Saturday.
We still went down to both shows & what a day we had, very tiring but awesome.
Oh well at least now I can finish it all before it comes out, next deadline has been set which is DC11
I have about a month to complete the hole project.
List
Finish smooth engine bay
Inter cooler & piping
Exhaust
Body work ??? may be a repaint or a wrap ??? I dont know yet but I want to stay with arches.
I.C.E
That is it I think.
Next up date coming up later on today.Last edited by Bespoke Division; 05-16-2011, 05:37 PM.
