I liked the Superleggeras, but I LOVE the RSs with this color.
PRO-STAR's e36-build
Originally posted by yurotrash View PostI liked the Superleggeras, but I LOVE the RSs with this color.
Originally posted by Doesn't Matter View PostWow wow wow, so beautiful. What are the specs on the RS's?
Better pics, NOW.
Something I don't understand.
You said your wheels are RS308 & RS309, which means they're 8x17 ET7 and 9x17 ET25 with 5x114,3. You also stated you're running adapters.
Even assuming your adapters were only 15mm thick, which would put you at an ET-8 for the front, the wheels would have to stick out way more than that.
What am I missing here?
correct the rears a fitted with adapters as of the front well i did try out the adapter's and it gave me hella poke...which i didnt like so i had them re-drilled then i did this and all worked outTHANKS to OKIN.
Originally posted by Okin View PostMe thinks you have to do some things with them lights too.... HmmmmKay.Seems a bit crooked.
I had a similar scenario fitting my wheels. All 4 corners had to be rolled and pulled, and then I decided to loosen up the bolts where the fender, filler and cover meet and pull them out/align and tighten. Bought myself about another inch of clearance up front.
Ah, awesome! Gonna have to try this... Thanks mate!
