Alfa Romeo Spider 3.7L 24V V6 Build
This topic is closed.
  • Ram-Air Cove Canards
    With the new re-angled diffuser slates out back on the block soon, I felt that this line should be brought up front as well.
    Now, as functional as the front ram-air coves are, that area was a little drab and needed some punching up. Enter the front canards/ram air deflectors - diffuser slate inspired.
    A quick mock-up proved to give me the form and function I was after. With slightly angled for an aggressive look, the slates played off the curvature of the main panel very well.
    Mind the fitment of the fangs/canards in these shots. They're just mocked and moved a bit due to the many times the bumper was on and off during the adjustments for spec.
    Up close.
    Sorry for the poor picture quality. It was quite late when I wrapped.
    street
    form - function - stance
    • things keep getting better and better!!! very nice work man!!! (where can i get some of that gold foil? thanks)
      • Reply.
        Thanks mateo m3! I got my gold foil here: http://www.elephantmotorsports.com/h...old-p-526.html
        street
        • Spider Update.
          I'm now using Flickr for uploading. So I hope this corrects the problems some members have had with no visible pics. Please let me know if anyone cannot see the new uploads from here on out.
          Ok, I've moved into the interior and have started formatting the gauges. I decided to utilize the stock pod. So I gut the internals and lined up the new formation. It was a little tricky to carve the top three ports as the pod is quite fragile and great care had to be taken when drilling.
          I used a hole saw and after a TON of measurements, I started in and drilled out the ports. There were a couple tense moments as the holes came VERY close to the speedo and tach. But with a soft and patient touch, it came out perfect.
          Here's the mock after the holes were drilled. Next up will be to take care of the remaining gaps from the stock gauges.
          027 (1024x768)
          But before that, I used some flat black vinyl and wrapped the smaller gauges exterior to blend it into the pod.
          024 (1024x768)
          Here's a top view showing the vinyl wrap.
          030 (1024x768)
          Next up was fabricating an aluminum surround to flush the gauges.
          033 (1024x768)
          Then I applied some more vinyl to the new surround that blocks all the previous gaps.
          035 (1024x768)
          In car spec check.
          045 (1024x768)
          Top view showing the levels. I love the fact that it's not just a simple flat panel. It's all black . But with the brushed bezels and upper step, it pops very nicely.
          052 (1024x768)
          From passenger side. The holes between the speedo and tack will host one of a few concepts I have on deck. More on that section soon.
          053 (1024x768)
          street
          • Glad to see some updates. Looks great as always. What are your plans for the gauge faces?
            • Originally posted by street View Post
              street
              Thanks man!! keep up the good work! i open this thread up everyday is like my spliff, i just can't leave it alone
              • Replys.
                Thanks Bro! Those are the full gauges. The faces black-out when off. Then look like this when on.
                008 (1024x768)
                street
                Thanks Bro! More on the way!!
                street
                • Spider Update.
                  I spent the limited time I had fabricating the belly pan dive plates for both medial and lateral edges. These plates serve a dual function - keep the under body air from being disturbed and carry the exterior line of the body.
                  It's a crappy half-focused shot. Will get better ones tomorrow.
                  CCW's fit very well but the fenders could use a touch more breathing room in the area of a 1/4 inch. Nothing major. I'm on it.
                  036 (1024x768)
                  street
                  • dude i love this car you have done some great work to it
                    the VW community is weird. dont try to understand, its like understanding africa.
                    Instagram: bigslowchevy
                    • another sweet update!
                      gauges are cool accent on an otherwise unique car!
                      Floccinaucinihilipilification
                      • I'm glad you were able to narrow it down to 3 gauges.
                        I would personally paint over the auto meter lables though
                        Hatchbacks, wagons... It's NOT all the same. You want in? Don't get a mazda 3, get a mazda 6 wagon. Don't get a wrx get a legacy wagon. and theres a reason the A3 isn't called the A3 avant... Scion does not make a wagon it makes a weird van, but no wagons
                        Sincerely,
                        The Wagon Mafia:Inner Circle
                        P.S. Is your tail a wagon?
                        Show cars are lame.
                        • Great progress, love the attention to detail that is being put into this unique project. Keep it up.
                          Internet high five for you.
                          • Replys.
                            Thanks Madhatter! The car reflects my personality - in what I'm in 150% or nothing. I **** half-ass shit.
                            street
                            Thanks P78! Glad you can see the images again. Looks like Flickr is the link! And you can ALWAYS expect sweet updates. One thing i can't stand, are threads with mindless chatter. That being said, everytime you see my name attached to an update, rest assured, I'm not chiming in to talk about the weather or what chick I saw the other day. I'm out to do damage!!
                            street
                            Yeah, it just worked out that way. Sometimes drafts are just a direction. Not always a solid path.
                            street
                            Thanks nellydragracer! To me, detail work is something that would annoy me if I didn't do it, therefore I must!!
                            street
                            • New Rollers - CCW Advanced!!
                              A few shots and a vid of the new set-up!!
                              street
                              023 (1024x768)
                              004 (1024x768)
                              030 (1024x768)
                              [ame="http://www.youtube.com/watch?v=DQn4GMD5W_I"]YouTube - ‪Alfa Romeo Spider - 3.7L 24V V6 Part 12‬‏[/ame]
                              • Ow yeah! Sick ride dude!
