I know some of you already saw this in the intro section, but I thought I better step up and start a thread in the build section. I am currently working on the driveline. Designing and building the torque tube, drive shaft,clutch shaft bearings and support housing, as well as the input shaft supports and bearing housing. That may take some time because I have to get a flywheel first....for a Northstar.
I am also about to remove the steering box and all linkages to fab in the Cadillac variable assist rack in its place. If I say it quick it sounds way easier.
So because I suck at 'puters you'll have to follow along via Photobucket link.....cool?
Don't worry about the stance at this point, it has to run before it can crawl.
Gordo.
Gordo.
