advice: if youre trying to stretch tires, go for wheels at least 8 inches wide or more. 7 and 7.5 are hard to make look good, and find tires for
'08 Black Nissan Sentra Spec V
So 17's that are at least 9 inches wide ok got that.. but for wheels ima have to save up for em from now so im open for suggestions but i want bulky looking wheels thatll make the car look aggressive. Ima be getting the car painted a matte' black and would like gold wheels to go with it and with an aggressive stance. but not so much poke prolly flush with the fender
I strongly disagree that 18" is too big.
You can do a 225/35 18 that is shorter than stock, or a 225/40 18 that is the correct overall diameter, and use a 9" or 9.5" to stretch it a little bit, allowing flush, or nearly flush fitment.
17" isn't a bad idea, but you'd have to run substantially shorter tires than optimal to get away from a chunky tire look that isn't flattering with a stretch.
Lower your car first, so that you can see how much wheel gap you have, and how much ground clearance remains, and know how much room you have for wheels.Last edited by Guest; 12-06-2010, 08:18 PM.
Yeah man, no reason to not ask questions. It's definitely a good thing.
I would say lower first, because I feel, personally stanceworks has been more about the low life than the wheel life.
I'm hella sunk on 14's with huge amounts of meat around my wheels, but I'll still show up to meets because low is the lifestyle to me.Christof Goulart
FCGoulartDesign.
Originally posted by medievalb16 View PostSo go low first before buying rims ? Thought it was the other way around lolOriginally posted by runningpanda View PostJust do your thing, man. What do you want to come first, low or wheels?What Hotsauce said.Originally posted by Hotsauce View PostLower your car first.
There's is a very logical reason to lower your car first: you know what your clearances will be.
If you're shooting for a specific fitment, you need to know how much room you're going to have so you can do it right the first time. Your coilovers may change how much room you have on the inside, your fender clearance will change both inside and outside, you will be able to see if where your tire will hit when you steer, and you'll see how much ground clearance you have left, all of which play a role in determining what the optimal wheel and tire combination is.
Work smart, not hard.
edit: and don't cut your springs, that's just stupid.
Haha yeah cutting your springs is bad for most, I guess. I haven't had a single issue, the car even rides really well still and nothing's blown up on me. So I'll continue to be the
Don't call it stupid, though. Just say you would recommend never doing it for your opinions.Christof Goulart
FCGoulartDesign.
