As soon as I saw it on instagram, I couldn't believe it! What made you wanna go on air? It seems like going bags is the new trend.....not that it's a bad thing cause it still requires money lol.
My Budget Build.
whats up dude ! thanks man yeah i cant wait to install em. i will deff be taking pics. found a fabricator this week to make my brackets after that the install is a go.Originally posted by Kinghorn View PostCant wait to see the 202 on bags!
It'll look good, and I heard your almighty in terms of installing bags? Im envious of you and your benz bro! Put up some post install pics for me, thanks! ----(By the way, its Andrews little bro)
!!!Originally posted by scweet14 View Postjust thought I should share this with you. found on *cough* *cough* ntancesation.
thats a clean shot to bad its from the darkside
well a few reasons. Ive been static since i got the car , I have two friends who own newer mercs on air. one i borrowed for a couple of days. my brothers car is on air and a few other people who i know / have ridden in their cars on air. Between that and wanting more low made me do it. I chose paddle valves though, nothing fancy.Originally posted by Chuckdee View PostAs soon as I saw it on instagram, I couldn't believe it! What made you wanna go on air? It seems like going bags is the new trend.....not that it's a bad thing cause it still requires money lol.
Originally posted by Rob&co View PostOhhh sn!
I wish they would have waited till my car was empty though LOLZ
my passenger is hella on instagram or something.
been a while since i updated this but the 202 is now bagged as many of you already know here is a shot from IG for those who havent seen it. will be updated the thread soon enough. but until then. I tease you all
maybe like a inch and a half or two. I still want more low. Thinking about removing sway bar to see if that is holding it up any.Originally posted by Rob&co View Posthow much lower did it get you?
DAT bagged life. i love you (i mean it)Originally posted by SD202 View Postbeen a while since i updated this but the 202 is now bagged as many of you already know here is a shot from IG for those who havent seen it. will be updated the thread soon enough. but until then. I tease you all
Broke the Budget. Bagged now. No more static.
just some of the work that i did myself. Will get some bracket shots soon even though i did not weld or fabricate those. just did the easy stuff like dremel out some stock bits, Mold a metal gauge plate that was cut out from a gauge panel. to the stock dash unit that was used for a in car phone from 1996. molded the switches into the ash tray. Was going to go a completely different direction than it ended up as far as the interior pieces go. As running the air line proved to be a challenge the W202 dash doesnt have much room for air lines and fittings after the switches and gauges are added. Also painted my tank and prepped a MDF board that held the inline 30 amp fuse and 12v40 amp relay as well as the compressor. I made it so that the tank and comp could be easily removed from the trunk. nothing fancy. but it gets the job done. And to disconnect all i have to do is unhook the power , ground, and keyed ignition. I ran that wire from the dash I used the cig lighter for this as it was removed to make room for the switches. The gauges lighting is wired to my shifter light that illuminates the P R N D 3 2 gear selections when my lights are on. My setup consist of 4 paddle valves. 1/4 air line. 4 Slam specialties ss5 bags. two dual needle illuminated gauges. one single needle gauge for tank pressure. A single 400c viair compressor. accuair 5 gallon tank Onto the pics.
mock up.
the day i tried to mock everything up is when i realized i had to completely change my original plan for this to accommodate the limited space and not look to terribly ghetto rigged. as i was working with limited tools and supplies for everything.
this is not how i ended up doing it. although it did seem like i could make it fit in there cleanly.
running the air line was no fun
the dash ended up looking like this. heres a before and after for those who arent familiar with W202 interiors
aired out.
thanks man ! was fairly simpleOriginally posted by TruTaing View PostDude. That's awesome. Great work!
thanks dude. Im still sorta on the fence about the switches. I think i want to redo them so that they are easier to get to when in park.Originally posted by Miroteknik View PostAwesome install on the interior!
