Eurowise Project 500hp turbo awd 1984 rabbit GTI
  • #76
    there is just so much consistent fabrication work
    Jacques Cousteau could never get this low
    • #77
      [quote name='Booster' timestamp='1291338756' post='104439']
      5x100
      [/quote]
      correct.
      Updates today on the back to front suspension.
      customer wants to still maintain a pretty aggressive stance and minimize wheel gap. In order to achieve this with the new taller spindles raising the strut towers will be done. This will give us 1.75 inches in height drop without adjusting the suspension and sacrificing ride quality.
      shot before raising
      shot of the passenger side strut tower top cut off and this section will be extended and cap will be welded back on
      half finished product, welds will be grinded down and smoothed out
      side profile of suspension lowered
      rear shot
      tires are 205-40-16 all around used just for mock up. Yes we know they're backwards
      roll cage also mocked up
      Specializing in Volkswagen, Audi, and BMW service, performance & Fabrication in Charlotte North Carolina
      • #78
        I can't believe the fabrication work in here! Seriously one of my favorite current builds...
        • #79
          we went back thru and welded the inside of the strut towers
          then grinded down smooth
          drivers side
          • #80
            completed seam welding the entire car. The rabbit should be 10x stronger than stock with all the structural bracing and welding of the panels.
            also finished the drivers strut tower
            before
            after
            started working on the dash today, shortened and modified the factory R32 dash support brace and welded\bolted it in place
            with dash bolted in place
            dash was shorted approx 5 inches on the side and about 4-5 inches in the front along the windshield
            with the dash being almost 5 inches more narrow the steering column stuck out way too far and we wanted all the steering wheel and dash trim pieces to light up like OEM so we had to modify and shorten the entire steering shaft, u-joint, and all the attaching parts
            now the steering wheel could be bolted up
            • #81
              i.want.your.life.
              www.flickr.com/theryp
              • #82
                Originally posted by ryp93 View Post
                i.want.your.life.
                i have succesfully read through this thread 5 times with my mouth wide open.
                • #83
                  its coming a long way fast.you guys know how to work.
                  • #84
                    damn shit is straight moving!
                    • #85
                      can't believe you cut up the r32 for the rabbit. major props, mate..
                      • #86
                        niceee. cant wait to see the finished car... and that interior is going to be awesome
                        • #87
                          Wow!!!!!!!!!!
                          • #88
                            This is the best build thread i've ever seen. Major props guys
                            • #89
                              Customer was against the idea of running the r32 dash in the car, but we insisted the customer drive up and entertain the idea..... having said that, it looks 10X better in person than it does in the pics. So, basically spent an hour "discussing" wheel setups (i.e. backspacing, offsets, diameter, camber, turning radius, and everything under the sun in regards to set of wheels). We have some relatively serious issues to work out now (first of hopefully a few setbacks) but the long of the story is we're going to run a staggered 16" setup. Customers considering the build will be both a compromise of show and go.
                              Took the wheels off project owners corrado to help give us some relative perspective....
                              We also worked on the rear fender wells since the floor pan was transfered and the rabbit fender wells would be too small and more work to integrate we purchased a 14" wide motorcycle fender and cut it in half and modified it to fit into the rabbit. turned out quite nice
                              Oil pan clearance...
                              began building the eurowise r32 short runner manifold
                              A pic of the what it will look like when done.
                              • #90
                                looks dope. im wondering why hes not running dry sump.
                                -Instagram@jdjurhuus
                                Stretchsaurus and Pokemon.
