built intercooler bracket\brace
made the upper and lower intercooler hoses
made out of stainless pipe with silicone hose ends
the fans were mounted next. with the little amount of room we had to work with we had to run a staggered fan setup
top of the fan on the passenger side had to be modified to clear the intake manifold and make room for engine movement
the fans are held in place with steel stock rod and brackets were made to bolt fan into place instead of using zip ties
with material removed from the passenger fan we made a small steel shield to act as a cover to prevent anything from contacting the fan blades
