Aussie Random Thread.
This is a sticky topic.
  • oh true?
    Single|Works
    single is a lifestyle
    S I N G L E | W O R K S - Loneliness is a Lifestyle
    • Hahahah !
      • Originally posted by anth
        • Comment
          • need moar offensive gangsta rap to pump in mah car wif da windows down wen going past a strip of cafes/restaurants. Makes me look like a hard cunt.
            • face down arse up thats the way we like to fuck
              usually gets quite alot of looks
              • some one tell me im not an idiot for turning down $31ph to stay at my job
                • Originally posted by TRaNz View Post
                  Need my "face warmer"?
                  • hey guys, i used http://www.willtheyfit.com to 'check' some measurements cos im retarded
                    old = 15x8 +/-0 w/ 195/50
                    i then typed in the specs of the wire wheels with same/slightly smaller tyre
                    new = 15x7 -05 w/ 195/50 or 195/45
                    and on that pic it sits just a bit closer in the guard
                    now what i wanna know is do the adaptor things effectively lower the offset slightly? eg, make it -10
                    ヤフオク!は、誰でも簡単に売り買いが楽しめる、日本最大のネットオークションサイトです。圧倒的な商品数を誇るヤフオク!で、落札・出品してみませんか?補償制度もあります。
                    and would those wire wheel towers be fine for these wire wheels?
                    how do those wire wheels mount to the towers?
                    • Can't realy answer your question exactly Luke since there isn't enough information there but here are a couple of possible scenarios
                      1) The wheel hub on the other side has a recess for the wheel nuts and the wheel studs and you can use those wire hub towers, assuming the hub/tower adapter is 5-6mm then yeah your offset will effectively be -10 or -11
                      2) There is no recess for the wheel nuts in the hub of the wheels, this scenario is you are pretty screwed and would need a wire tower adapter that is 15mm thick or so to clearance the wheel nuts and will push the offset out more.
                      3) The wire tower adapters don't match the wheels
                      There is realy too many variables for me to suggest. maybe research that brand of wire wheels and make sure the hub bore and the everything matches up and double check to make sure they have too to recess the wheel nuts and studs
                      • thanks roman
                        • someone buy.
                          I HAVE A CAR !
                          IT - HAS - DIFFERENT - PARTS - ON - IT
                          ARE U INTERESTED?
                          SOICHIRO HONDA SAYS: 'NO'
                          • tempted to ask if they will fit my skyline if i roll the guards
                            • ah damn those wheels are 5x5,5" not 5x4.5"
                              • Roman,
                                Your sig = boss.
                                What the fck's scar'non?
                                IG: @sebastienaudeon
                                1974 Porsche 911S
                                *pats Sebs head*
                                there there.
                                keep calm, go mash your face on a car window.
