so I'm about to put 15mm spacers on my civic & I'm going to need to shorten the stock lug studs that's on the car.. will it be alright to grind them down short enough for the wheel to fit or do I need to replace them with shorter ones?
4x100 15mm spacers help?!
I don't know if I completely understand what your asking...
If your installing 15mm spacers, the stock lug studs will be shortened because your taking up 15mms of thread. You will need to extend your lug nuts if you do not have enough thread - not shorten them.
But to answer your question - You shouldn't grind them down you will ruin the threads. If you choose this route I would first thread on a Die (from a tap & die set) Once you've got your desired length you back the Die off correcting your thread.
