You can get a power kit from Bag Riders or you can just get a generic amp wiring kit from wherever. The Bag Riders kits come with really nice wire, though, so I think they're worth it. You'll need the wiring sized appropriate to the compressor or compressors you buy.
Here's my thoughts on a water trap: Water trap or not, you still need a tank drain. If you install a manual drain like the Schrader valve that comes with the Bag Riders kits or a screw valve, a water trap per compressor is nice in our climate. The other option is to use an electric drain, in which case I don't think water traps are necessary, since it's so easy to purge the water from the tank.
The only thing you should need to add to the bag kit and manual management system is a safety valve set at whatever the lowest pressure rating item on the high pressure side of your system is rated at. So, if you run a Viair 444c and a tank rated to 200 psi, get a 200 psi safety valve. If you run a 150 psi compressor and/or a 150 psi tank, get a 150 psi safety valve.
Beyond that, you should think of how you want to lay out your system. What Bag Riders provides in their kit will allow only for a very basic installation. If you want hard lines or any kind of slick installation, you'll need to figure out what additional fittings you need to make that happen.
