I've heard that you will die if you do this, or that it doesn't make a difference. I'd like to know the truth. In Mike's e36 vid, there's several clips of him driving pretty hard. Is this fine to do? What about have some rwd fun? (Drifting)
Streched tires and performance driving
Almost all the people who say that stretched tires are dangerous, have not looked into it at all.
The bead of a stretched tire is 10 times stronger then the bead of your average tire. the amount of times I have heard people say "you'll roll the tire off the rim" is rediculous. In order to blow the bead, you need to hit a gutter and completely destroy your wheel.
You do run a slightly higher tire pressure, but that is a choice really. When drifting on stretched tires, the heat creates a higher pressure anyway.
As for a supposed "loss of grip", the sidewall being stretched doesnt play that much of a part when it comes to cornering. The stretch increases the stiffness of the sidewalls preventing tire roll, which if your suspension is setup properly, and you are running the correct tires, it wont handle any differently.
Drag racing is a different story, you want a bit of play in the tire to get the grip to the ground, but thats a different story. If you dont know much about drag racing then you dont need to worry about it.Originally posted by anthLucky they didn't come into your house and disrespect your whole family.
I run 38psi. I have run up to 45 before... All tires have a max pressure of around 55-65 psi, but they should be marked on the side wall. Ive also had them down to 20psi, and still driven on them.
At the end of the day, the psi you run will be relative to the way you drive.Originally posted by anthLucky they didn't come into your house and disrespect your whole family.
Driving hard on stretched tires is fine as long as the tire pressures are kept in check. I can't stand when people try and argue that it's BETTER for performance though bc it really isn't. There are benefits to running some stretch on performance applications but overall, a meatier tire will usually yield better results when compared directly to the same application with a more stretched tire.
I run 35-40psi on my tires
are there any guides, how much pressure goes in?
like 205/40/17 on 7.5.. (i know, not really stretched but still)Floccinaucinihilipilification
Should be in the fineprint on the sidewall.Originally posted by P78 View Postare there any guides, how much pressure goes in?
Thats not a stretch at all anyway lol...Originally posted by anthLucky they didn't come into your house and disrespect your whole family.
it is here for the government, my car won't pass with those tires (MOT, dunno what that's called in US, or AUS)Floccinaucinihilipilification
Most likely. Far as I can tell, that MOT is quite a bitch. So glad all I need to get inspected in NY is an OBD2 scan lolOriginally posted by Tuck&Poke View Postso how the hell are there so many cars in the uk with stretched tires? Swap on stocks for MOT?
