By adding more negative camber to the rear wheels, the toe gets thrown off and needs to be aligned, with stock 325i trailing arms and aftermarket adjustable control arms I am only able to get -6 degrees of camber because the toe adjustment is completely maxed out. Is there an aftermarket set of trailing arms i can buy to get more toe adjustment so I can get more negative camber without having my toe messed up? Or do I have to make custom trailing arms ?
E46 sedan, trailing arms with more toe adjustment??? Custom trailing arms?
This topic is closed.
I am just ready to get - 6 degrees of camber on the grounds that the toe alteration is totally pushed to the limit. Is there a post-retail set of trailing arms I can purchase to get more toe modification so I can get more negative camber without having my toe fouled up? Or, on the other hand do I need to make custom trailing arms ? Online Essay Writers UK
we are looking for adjustable anti-short. Id likes to add more anti-short by approaching the arm up into the bucket additional, as well as be able to correct it fast at the track for different setups.
WTF is with this thread. The whole thing looks like it was written by bots.
