I have had a lot of problems with air leaks! to start with I had more leaks than a net balloon! got it down to leaking like the titanic! I now have it nearly sorted but still a few minor leaks. can you ever get a 100% leak free setup? I have now just put 50 psi in each bag and have 50 psi in the tank and will check in an hour what has leaked from the setup.
right next question regarding bag psi and setup, I have not driven the car yet so have no real idea on what psi to run in the bags? I also have adjustable dampers/shocks.
So do you run with the dampers soft? or a harder setting?
Thanks
Thanks
