e36 Depo headlights // Need some help
  • e36 Depo headlights // Need some help
    Just picked up a set of the Depo Gen 4 headlights for my e36 328i, and they came with no instructions or wiring schematics. I've done many google and forum searches, and I have found some info, but nothing that really helps. If anyone knows where I can find install instructions or can provide them themselves that would be great!
    ||| mkv GTI - RIP || 69' w114 || 97' e36 328i |||
    search through bimmerforums. I seen alot of of diagrams on there
    Sugar Mama Build - http://www.stanceworks.com/forums/sh...ad.php?t=73298
      I've searched through bimmerforums and can't find anything that helps.
      So quick question for you guys... What bulb do I have here? An what kind do I need for these head lights?
        Bump.
        I contacted depo directly and they said, "it is company policy NOT to provide installation instructions"... Seems a bit weird to me.
          Where did you buy them from? I bought my ZKW's from ECSTuing and they said in the description that it's plug and play.. wasn't too hard to wire up. Trace wiring.
          Instagram: @mattragsdale
          '97 M3 build
            Bought them off of ebay. What bulbs are you using with your zkw's? did you make the switch to HIDs?
              Those two plugs (black & grey) plug into the already existing plugs that went into your old housing. ones for low beam the other is for high beam. That lone grey wire there is for your daytime running lights. They wire into the power wire of your blinker indicators I believe. And those bulbs right there are H1 bulbs. Hope that helps you a little bit. Good luck!
