On my BMW Z4M E86:
I got the KW V3 and I am in the middle of the installation. Got the front coilovers installed but when I tried to mount the wheels the wheel/tire hits the suspension so obvious that I can't even make the wheel come near the hub.
Measured the space and its about 25mm between wheel and hub if I leave 10mm (must keep 5mm minimum as install manual says) between inner wheel/tire to suspension.
Note my wheel/tire setup:
Apex Arc-8 size/offset:
F 18 x 9 ET42
R 18 x 10 ET25
Tire:
Front: 245-40-R18
Rear: 275-35-R18
Will I be fine with 25mm front spacers?? and 5mm for rear?
F 18 x 9 ET42
R 18 x 10 ET25
Tire:
Front: 245-40-R18
Rear: 275-35-R18
