Okay so here's the scoop. My lug pattern is 5x110. So any nice JDM wheel wont go on without adapters. Not a problem! I can run your standard 19x8.5,9.5 +40 ish wheel set without an issue using your standard 25mm adapters. But here's where the problem comes in. I have extended studs on the car. SO, the extended studs poke out of the adapter thus meaning only certain wheels can lay flat on top of the adapter. I need some clean wheel recommendations that will work for me. I have my eye on a set of AME shallen WX but I'm not sure if they are shaped like this in back....
heres a pic of what I need my wheel to look like in back. Notice the little pockets? They will allow the extended studs to rest in there and the wheel will sit flat.
