hi on my e36 im running a set of borbet 17" bs fronts are 8.5j et13 and the rear are 10jet20 im happy with the stance on the back,i have had the rear arches cut and done properly,now i come to the front i have wound the coilovers down as far as i feel safe you see the tire protrudes from the arches what i want to know is if i buy camber adjusting top mounts would it be enough to tuck the wheel under?, and what will this do for handling? will it screw it up? of course i would get the toe re-done you see on those e36 wings i dont think you can roll the arch without the inner arch liner coming loose at least thats what i have read on the net by the way its a 1995 328i coupe il put pics any help would be much appreciated oh im running 215/40 on the front[IMG]
[/IMG]
[IMG]
[/IMG]
[/IMG]
[IMG]
[/IMG]
