Gday, just wondering if anyone has had the problem of there e36 coupe window partially opening whilst driving. it happens at very random intervals. I've done the window switch initialising. still yet to drive the car and see if it does it again.
E36 coupe partial window retraction, window moves itself whilst driving :S
make sure the door catch is adjusted right, is any of the plastic on it worn? i had to replace both mine when i got the car
yeh, i adjusted the catch so many times with the old microswitches, with no luck, so i dropped the cash on new ones. passenger side door is still a bit iffy, but i need to replace the motor, adjust the glass, then adjust the hinges gotta love pillarless doors
It's the microswitch on the body of the car like previous posters said, a quick but limited fix is also applying a couple thin little layers of masking tape across it to essentially make it a bit "larger" of a target for the latch to hit..
