Honda heads!
  • Honda heads!
    hello, would a 9.5 wide wheel fit on the front of a civic (ef to be exact) with little issue?
    as for the offset whats the adequate measurements it needs? on a 9 a +15through25 is aggressive but a 9.5?
    slight pull and i wouldnt go over 205 on tires and your good.
    Golf 6 - OEM PLUS
      i run 16x7.5 +22 up front and 16x8 +11 in the rear, 205/40's all around. had the rears up front to see, and the back spacing for the 8 is about all that will fit and clear the spindle
      so fitting a 9 or 10 up front would require like a +12 or -3 offset and a fender pull/roll
      my setup before i repaint it tomorrow. and yes static.
      1970 Toyota Corona Mark II - project kyushabozo
      1995 mk3 vw golf - daily
        i had 15x8 +15 offset with 195/45/15 tire on my 89 ef and i had to hammer the shit out to the rear to pull it 1/2 inch out.
        '89 civic hatch 15x8 sportmaxx 501 +15 offset stolen and recovered without my wheels SOLD
        '93 civic sedan tbd
        '92 civic sedan cheviot reverse mesh
          thank you all for the help..yea its going to be at 0offset so fender role is a must
            9.5 on the front? Good luck.
            Originally posted by anth
              ^ +1 In for pics of this.
                +2
