haha spray some rhino lining truck bed liner under there.
E36 belly?
lol. huge difference between scratch resistant and the weight of the car dragging on the pavement at any given time. the forces aren't the same.Originally posted by Bruno730 View Postreportedly POR15 is chip and scratch resistant. i'll believe it when i see it though.
plus i'd rather have to keep coating it than having the frame rails rust out in 5 years.Originally posted by KielanI've had a lot more fun in my Dad's Prius than I care to admit.
BMW e23 build Thread
I understand that, I am a mechanical engineer. i do not need a lecture in physics. The point is that the product could potentially be more useful than a rubberized spray on coating, which would definitely come off, if it were scraped (as evidenced by the factory undercoating...)Originally posted by NegativeCamber View Postlol. huge difference between scratch resistant and the weight of the car dragging on the pavement at any given time. the forces aren't the same.
Furthermore, while surface rust could potentially be "scraped" off, it doesn't negate the fact the bare metal is subject to moisture and dirt, which will accelerate corrosion.
I don't get how nobody has this concern.
I run the fender liners, but I'm not as low as some (about 4cm / 1.5inch at the frame rails). I don't have any rubbing, so no issues there... if I were to go lower and would encounter rubbing, I'd still keep them, I'd just trim the top most portion so the wheel's got enough space to move. But the rear and front parts would stay on for sure. It just looks ugly when you can look THROUGH the wheel well to the bumper for example, imho.
Then don't lower your car.Originally posted by Bruno730 View PostI understand that, I am a mechanical engineer. i do not need a lecture in physics. The point is that the product could potentially be more useful than a rubberized spray on coating, which would definitely come off, if it were scraped (as evidenced by the factory undercoating...)
LOL obviously you're not getting my point Sean.Originally posted by SeanDub View PostThen don't lower your car.
For me, it's about doing things right. some people are OK with rubbing or baseball bat rolled fenders or fucked up frame rails. I'm not one of them though and it seems peculiar that in a community like this, nobody has been concerned with bare metal on frame rails.
i guess we aren't on the same page. read the posts by the OP. he wants to get "mad low." the picture that comes to mind is skrapez aka Josh's e36. that car was "mad low." any coating that you sprayed on, would be scraped off and would expose the metal regardless. you dont need a ME degree to understand you are sanding the product right off when that low.Originally posted by Bruno730 View PostI understand that, I am a mechanical engineer. i do not need a lecture in physics. The point is that the product could potentially be more useful than a rubberized spray on coating, which would definitely come off, if it were scraped (as evidenced by the factory undercoating...)
if you are rarely scraping any of the chassis, then you would be looking in the right direction.Originally posted by KielanI've had a lot more fun in my Dad's Prius than I care to admit.
