i have a 88 civic sedan dx and yesterday i planned on doing a straight pipe from my cat-back but realized that my welder was broken so i decided to just bring my car to a local shop and they brought it out the back with no problem... however, this morning i went to start the car and it was turning over very slowly, so i checked the battery acid and the battery was nearly dead as a door nail. so i went out a bought a new battery, but now, it's not even turning over as if the battery is dead, but my lights and everything else work when the key is turned on. does anyone know what could be the problem? thanks
starter problem?
1) Check fuses
2) Try using a screwdriver and bridging the contacts on your starter solenoid. Make sure the car is in neutral or park though lol. Don't run yourself over
StatusRacing.com
Configure YOUR Seat Here
Tel: 1.480.265.8600
Email: sales@statusracing.com
Fan us on Facebook
Auto or manual? If auto can be your neutral switch.
Best thing to do is check power at the starter motor. The main terminal you should get battery power, the other one you should get battery power when the ignition is on. Hope that helps
Also immobilised?
