Hi! im in the way of getting to the stance I want for the bimmer, but the rears are rubbing a little, and in long trips with bad roads, it annoys me a little. Im a noob in this stuff, so i think you can help me.... I just want a little camber in the rear, for looks and stop the rubbing, what are the most used methods for this? at which costs? Thanks!
Help me on camber on a E46!!
If your comfortable adjusting it, there's an eccentric bolt that gives (I think) about 0.5-1 deg of adjustment but in reality is quite a lot if you're only just rubbing
This is it here, bolt number 10:
Take it to your alignment shop and ask them to adjust it to give you the maximum camber. They can then adjust your toe to suit.
Pics!
*too slow
