help with e36
  • help with e36
    anyone in or near nj who knows about bimmers wanna come help me out with my e36 with swaping out my rear differential and ignition switch. i just dont wanna pay to tow it to a mechanic and then pay to fix it on top of that, it would be very much appreciated and i will pay
    thank you
    paris
    ps. also if you have tips on how i should do it myself thats also appreciated
    Not close enough to give a hand but if you have any questions, shoot me an email, I have swapped the diff in E36 many times.
    From memory
    -unbolt driveshaft (4 bolts)
    -unbolt torx bolts E12 on each side of driveaxle (6 or 8 I believe) careful not to strip or they are a bitch
    -unclip speed sensor
    -3 18mm bolts holding the diff to the rear subframe and diff mount
    They say you need to remove the exhaust but I usually get away with just disconnecting the muffler mounts and lowering it a few inches, gives enough room to remove it.
    www.euroWinnipeg.com
    www.E30S38.com
      ok will do, thanks for the info
