What are your thoughts/reviews on them? I'm really tempted to pick up some 20mm bolt-on spacers to help reduce my sunk syndrome in the rear. I've always kind of questioned the safety of them. I daily drive my car and want to keep it safe, of course. Thoughts?
For those of you running bolt-on spacers....
This topic is closed.
Just make sure to get the correct spacer for the vehicle. Make the spacer is match with the hub so that the bulk weight will be on the hub and not on the studs.
A 20mm spacer should not cause any problems if you get the right spacers. 4x4 guys are running 1,2,3 inch spacers and have been for years and years...
Like anything automotive, just do it right the first time!Current Project: 1988 535is --- Pics and Info When Its Worthy
The weight is not on the bolt unless you bolt them on incorrectly. Properly bolted and torqued wheels do not transfer weight on to the bolt with or without spacers. I like using hubcentric spacers for ease, not necessarily an issue of safety. I had 25mm's for about 8 months, thousands of miles of daily driving. Never even got loose.
ig: @jonnie86
