Hey guys.
1. Rear camber
As it is currently, my Touring has almost no camber in the rear. I want / need some more.
Now I thought I might try it first with just getting an alignment done and telling the guy to set it up for more neg. camber.
How much neg. camber is possible with stock parts?
I've been thinking about buying adjustable lower control arms for the rear, but I'm not sure if that's necessary to get the camber to where I want it.
Oh, fyi the Touring's got the same rear axle as al the other E36s apart from the ti.
2. Front camber.
I've been thinking about installing excentric M3 3.2 strut bearings.
If you mount them stock as is, they will add caster but remove camber. If you swap the left one to the right and the right one to the left, they will add caster and negative camber.
Anyone on here can tell me how much more camber they add?
1. Rear camber
2. Front camber.
