i heard a rumor that some toyota sway links will fit an e46 and are also shorter than stock? or are there any other "cheap" options available besides VMC? some help would be appreciated!
e46 sway bar end link options?
Tags: None
Both mine snapped....
Soooo the cheapest solution I have found is to just run without them lulz There is a clunking noise....but whatever I'm poor
But I have heard that a Toyota endlink works.... Hold on gimmie a sec....
*edit* Here ya go...
Originally posted by Stanc3yep, only the best of the best here!... :eeps:
seriously though....... Duralast part #18365... is beyond perfect..
I work at autozone so I scoured through all our endlinks on my day off and found these as a perfect match, i mean PERFECT. Perfect length, even the same thread size and pitch (the old link bolts will work) they are around 25 a piece still though.. check em out!
not sure if there from an echo exactly, but they are from a newer small sized toyota.
JDM foo.
Originally posted by southpawLast edited by RedE46Bimmer; 02-18-2010, 11:02 PM.-Brandon-
Originally posted by alexcruz View Post2007-2008 Impala SS rear swaybar endlinks work they are about 7" long. i just put mine on yesterday and they are perfect length if your dropped low. i took a picture of stock vs. chevy lol i can put it up later
Originally posted by Natedogg View PostI'm in uk and found hyundai coupe rear ones are perfect - not sure what you call the car in US - but there a blue stanced one on here on bronze rotas
Like my previous post said I picked a set of the impala rear end links up and installed them thursday night, I am happy to report they are doing an excellent job so far.
Psh. Who needs endlinks? :eeps:
sorry to bump an old thread, but i just installed some coils, and added shorter endlinks that iirc, were half the length of the stock link and now my sway bar is angled up at a weird angle.
Do any of you know how long the toyota end link that was mentioned is? i think i need one shorter than stock, but not quite the 4-5" one link i have now.I haz 4 wimz.need 4 more.
