Has anyone cut thier e30 bumpstops? i know you can, and i wanna, i could use the travel.
Bump stops???
Originally posted by Stephen View PostWell hellabad on r3v , who works for GC, said you can cut the billy bumpstops about one third. He has a little pic showing where to cut but how to get to the bumpstop inside the strut is beyond me. Maybe im overthinking it.
I do'tt run them.Probably should.
It's literally just the strut shaft, with a little piece of rubber that slides around it. Kind of like a washer, but rubber and thicker. Cutting it in half just makes it less tall so the strut can compress farther. It still slides on and sits there just like normal. To take it off the strut, cut it, and put it back on, it would probably take you 47 seconds.
Originally posted by Stephen View PostBUt you have konis, and those dont sound like internal bumpstops to me..
Originally posted by Tuck&Poke View Posti could have sworn sombody sold "clip on" bump stops. They look like little "C" shaped things that you would slide around the rod on the shock and you could stack them to make it whatever size you need
