Yeah, I just went back and re-read the 1st page. I saw that you already tried caster, but I think you should be running lower not higher caster. Try going really low caster. Your steering wheel isn't going to return to center as easily, but it's the price you gotta pay lol.
As far as comparing your car to an E36, that doesn't really help. If you were comparing your car to another E30, sure...
I've tried the caster with the max and minimum amount's that I can get and there isn't really a difference. The reason's I'm using Josh's car as an example are because I've worked on and driven it multiple times, it sits the same as mine on the same wheels and has the same type of suspension.
I'm starting to think that e30's might just have thin fenders. now that it's just one layer thick I can move them a bit with just my fingers. Maybe I'll try repairing this set with some thicker metal and see if that helps.
Well 205/40's helped a lot, I can turn most of the way to full lock and still reverse. They have the unfortunate side effect of cutting my ground clearance in half but I guess it's a worthy tradeoff. I have a meh fender that isn't messed up yet, I'm gonna use that as a test fender before I get actual good ones and a respray.
